[Ovmsdev] ssl cert
Shane@Kilve-Engineering.co.uk
shane at kilve-engineering.co.uk
Wed Mar 31 20:11:19 HKT 2021
My bad
But well spotted and thank you for sorting
Regards
Shane Hunns
Kilve Engineering Ltd.
0792 0729 316
> On 31 Mar 2021, at 13:05, Michael Balzer <dexter at expeedo.de> wrote:
> Shane,
> found it: you've broken it by your pull request #596, and I've broken it by not recognizing this when reviewing your PR.
> You added a revert of the mongoose submodule checkout point to your PR:
> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/596/files#diff-5ab2a552f205c6fe33b157a2dc27590aa7258070eb926a8fc3719657dbcc2fd4
> I've pushed the fix & published a new build to edge.
> Am 31.03.21 um 13:21 schrieb Shane at Kilve-Engineering.co.uk:
>> It’s using time from gps as that’s ticked
>> Only started last few days but is ok on an older bin file
>> Regards
>> Shane Hunns
>> 0792 0729 316
>>> On 31 Mar 2021, at 12:13, Michael Balzer <dexter at expeedo.de> wrote:
>>> Strange. No issues here, no reports from other users… the cert hasn't changed in a while and is valid for another month. The CA cert is valid until september.
>>> Does your module have the right system date?
>>> Am 31.03.21 um 12:54 schrieb Shane @ Kilve Engineering:
>>>> Have you broke something?
>>>> E (2710323) ovms-server-v2: mg_connect(ovms.dexters-web.de:6870) failed: Invalid SSL CA cert
>>>> E (2710323) ovms-server-v2: Status: Error: Connection failed
>>>> I (2770323) ovms-server-v2: Connection is ovms.dexters-web.de:6870 maxushunnsnet
>>>> I (2770323) ovms-server-v2: Status: Connecting...
>>>> E (2770333) ovms-server-v2: mg_connect(ovms.dexters-web.de:6870) failed: Invalid SSL CA cert
>>>> E (2770333) ovms-server-v2: Status: Error: Connection failed
>>>> I (2830323) ovms-server-v2: Connection is ovms.dexters-web.de:6870 maxushunnsnet
>>>> I (2830323) ovms-server-v2: Status: Connecting...
>>>> E (2830353) ovms-server-v2: mg_connect(ovms.dexters-web.de:6870) failed: Invalid SSL CA cert
>>>> E (2830353) ovms-server-v2: Status: Error: Connection failed
>>>> I (2890323) ovms-server-v2: Connection is ovms.dexters-web.de:6870 maxushunnsnet
>>>> I (2890323) ovms-server-v2: Status: Connecting...
>>>> E (2890323) ovms-server-v2: mg_connect(ovms.dexters-web.de:6870) failed: Invalid SSL CA cert
>>>> E (2890323) ovms-server-v2: Status: Error: Connection failed
>>>> I (2950323) ovms-server-v2: Connection is ovms.dexters-web.de:6870 maxushunnsnet
>>>> I (2950323) ovms-server-v2: Status: Connecting...
>>>> E (2950323) ovms-server-v2: mg_connect(ovms.dexters-web.de:6870) failed: Invalid SSL CA cert
>>>> E (2950323) ovms-server-v2: Status: Error: Connection failed
>>>> I (3001323) housekeeping: 2021-03-31 10:07:14 BST (RAM: 8b=72312-80768 32b=10360)
>>>> I (3010323) ovms-server-v2: Connection is ovms.dexters-web.de:6870 maxushunnsnet
>>>> I (3010323) ovms-server-v2: Status: Connecting...
>>>> E (3010323) ovms-server-v2: mg_connect(ovms.dexters-web.de:6870) failed: Invalid SSL CA cert
>>>> E (3010323) ovms-server-v2: Status: Error: Connection failed
>>>> I (3070323) ovms-server-v2: Connection is ovms.dexters-web.de:6870 maxushunnsnet
>>>> I (3070323) ovms-server-v2: Status: Connecting...
>>>> E (3070323) ovms-server-v2: mg_connect(ovms.dexters-web.de:6870) failed: Invalid SSL CA cert
>>>> E (3070323) ovms-server-v2: Status: Error: Connection failed
>>>> I (3130323) ovms-server-v2: Connection is ovms.dexters-web.de:6870 maxushunnsnet
>>>> I (3130323) ovms-server-v2: Status: Connecting...
>>>> E (3130353) ovms-server-v2: mg_connect(ovms.dexters-web.de:6870) failed: Invalid SSL CA cert
>>>> E (3130353) ovms-server-v2: Status: Error: Connection failed
>>>> I (3190323) ovms-server-v2: Connection is ovms.dexters-web.de:6870 maxushunnsnet
>>>> I (3190323) ovms-server-v2: Status: Connecting...
>>>> E (3190323) ovms-server-v2: mg_connect(ovms.dexters-web.de:6870) failed: Invalid SSL CA cert
>>>> E (3190323) ovms-server-v2: Status: Error: Connection failed
>>>> I (3250323) ovms-server-v2: Connection is ovms.dexters-web.de:6870 maxushunnsnet
>>>> I (3250323) ovms-server-v2: Status: Connecting...
>>>> E (3250323) ovms-server-v2: mg_connect(ovms.dexters-web.de:6870) failed: Invalid SSL CA cert
>>>> E (3250333) ovms-server-v2: Status: Error: Connection failed
>>>> I (3301323) housekeeping: 2021-03-31 10:12:14 BST (RAM: 8b=72312-80768 32b=10360)
>>>> I (3310323) ovms-server-v2: Connection is ovms.dexters-web.de:6870 maxushunnsnet
>>>> I (3310323) ovms-server-v2: Status: Connecting...
>>>> E (3310333) ovms-server-v2: mg_connect(ovms.dexters-web.de:6870) failed: Invalid SSL CA cert
>>>> E (3310333) ovms-server-v2: Status: Error: Connection failed
>>>> W (3717913) websocket: WebSocketHandler[0x3f84d2d0]: job queue overflow resolved, 1948 drops
>>>> I (3730323) ovms-server-v2: Connection is ovms.dexters-web.de:6870 maxushunnsnet
>>>> I (3730323) ovms-server-v2: Status: Connecting...
>>>> E (3730353) ovms-server-v2: mg_connect(ovms.dexters-web.de:6870) failed: Invalid SSL CA cert
>>>> Regards
>>>> Shane Hunns
>>>> 0792 0729 316
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210331/714fcb3a/attachment-0001.htm>
