[Ovmsdev] Multi frame query
Mon Mar 29 01:39:22 HKT 2021
Didier,
the PID scanner normally works perfectly with multi frame responses, but
I haven't had a response that long yet.
For 1503 bytes, 215 consecutive frames need to be transmitted. The PID
scanner requests these to be sent with 25 ms separation time, so they
should need 5.375 seconds.
Maybe some frame gets lost, or maybe the device doesn't allow a
separation time that high for a transmission that huge.
Your log quote wasn't from the re-pid component but from obd2ecu, which
has nothing to do with the RE tools. You should raise the log level for
re-pid to see more info. Another tracing option is to use the CAN log
monitor.
Btw, you should never need 30 seconds timeout for a PID poll, as the
scanner checks against the last frame reception.
Am 28.03.21 um 17:52 schrieb didier at ernotte.com:
> I am investigating some PID with very long data. I am using the PID
> scanner for this.
> When I turn on the log level debug , I can see this as the first repy
> D (1456677) obd2ecu: Rcv 7ec: 8 (15 df 62 48 83 0 0 0)
> From the Canbus doc, I understand that the first "1x (15)" tells me
> that this is the first frame of a multi frame, and the length is "5df"
> . The Pid scanner seems to return only "df", not "5df" data, and I can
> see in the log that I have around 1500 byte returned, not 220. Any
> explanation ? anyone see this problem as well ? The scan command is (I
> had to hack the code to allow timeout > 10sec)
> re obdii scan start 1 7e4 4883 4883 -r500-7ff -t22 -x30
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210328/4c93e60d/attachment.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210328/4c93e60d/attachment.sig>
