[Ovmsdev] Multi frame query
didier at ernotte.com
Sun Mar 28 23:52:17 HKT 2021
Hi,
I am investigating some PID with very long data. I am using the PID scanner for this.When I turn on the log level debug , I can see this as the first repy
D (1456677) obd2ecu: Rcv 7ec: 8 (15 df 62 48 83 0 0 0)
>From the Canbus doc, I understand that the first "1x (15)" tells me that this is the first frame of a multi frame, and the length is "5df" . The Pid scanner seems to return only "df", not "5df" data, and I can see in the log that I have around 1500 byte returned, not 220.
Any explanation ? anyone see this problem as well ?
The scan command is (I had to hack the code to allow timeout > 10sec)
re obdii scan start 1 7e4 4883 4883 -r500-7ff -t22 -x30
Didier
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210328/cdc55a46/attachment-0001.htm>
