[Ovmsdev] New vehicle: Hyundai Ioniq vFL
Thu Mar 25 15:22:58 HKT 2021
Kirmo,
welcome :-)
Henri was mostly interested in the SOC, which works for him. The other
metrics and the state management could use some more testing.
To help with the speed decoding:
> If you can help with logs on this, enable file logging and do a test
> drive with level verbose on module v-hyundaivfl. Try to maintain a fixed
> maximum speed for 20 seconds for reference. Send me the logs and the max
> speed.
If you later want to explore and add more PIDs, I can show you how do
reverse engineering and PID monitoring, and how to integrate more PIDs
into the code.
Am 24.03.21 um 16:27 schrieb Kirmo Uusitalo:
> This is great news! I am happy to contribute.
> I am a newbie in OVMS with Huyndai Ioniq 28 kWh (2017). I haven't yet
> received the hardware, but I have bluetooth OBD-II dongle an EVNotify
> installed in my s artphone.
> What exactly should I do to help?
> Regards, Kirmo
> On Wed, Mar 17, 2021 at 10:47 PM Michael Balzer <dexter at expeedo.de
> <mailto:dexter at expeedo.de>> wrote:
>     Everyone,
>     by request of Henri Bachmann on the german GoingElectric forum, I've
>     added the Hyundai Ioniq vFL (28 kWh).
>     The implementation is based on the reverse engineering data
>     published by
>     the EVNotify project:
>     https://github.com/EVNotify/EVNotiPi/blob/master/car/ioniq_bev.py
>     <https://github.com/EVNotify/EVNotiPi/blob/master/car/ioniq_bev.py>
>     Module Documentation:
>     https://docs.openvehicles.com/en/latest/components/vehicle_hyundai_ioniqvfl/docs/index.html
>     <https://docs.openvehicles.com/en/latest/components/vehicle_hyundai_ioniqvfl/docs/index.html>
>     Henri has tested the module, but more tests from other Ioniq
>     drivers are
>     welcome.
>     One of the PIDs needs more data/logs: the "driveMotorSpeed" didn't
>     match
>     the actual speed on Henri's tests. That PID isn't used by the
>     EVNotify
>     system so may be wrong, or could be RPM.
>     fixed
>     the max
>     speed.
>     Regards,
>     Michael
>     Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal
>     Fon 02333 / 833 5735 * Handy 0176 / 206 989 26
>     _______________________________________________
>     OvmsDev mailing list
>     OvmsDev at lists.openvehicles.com <mailto:OvmsDev at lists.openvehicles.com>
>     http://lists.openvehicles.com/mailman/listinfo/ovmsdev
>     <http://lists.openvehicles.com/mailman/listinfo/ovmsdev>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210325/07b1b6ec/attachment.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210325/07b1b6ec/attachment.sig>
