[Ovmsdev] 3.2.016 released to EAP
Tue Mar 16 14:43:14 HKT 2021
Released on www.openvehicles.com <http://www.openvehicles.com/> as well.
> On 15 Mar 2021, at 4:25 PM, Michael Balzer <dexter at expeedo.de> wrote:
> Signed PGP part
> No issue reports so far. I've released 3.2.016 to "main" on my server.
> Am 06.03.21 um 14:34 schrieb Mark Webb-Johnson:
>> Sure. Will do on Sunday.
>> Mark
>>> On 5 Mar 2021, at 9:30 PM, Michael Balzer <dexter at expeedo.de> <mailto:dexter at expeedo.de> wrote:
>>>  Everyone,
>>> I've just tagged the 3.2.016 release, uploaded it to my "eap" directory and published the info on my site.
>>> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/releases/tag/3.2.016 <https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/releases/tag/3.2.016>
>>> https://dexters-web.de/firmware-release-3.2.016-text_98.en.htm <https://dexters-web.de/firmware-release-3.2.016-text_98.en.htm>Mark, I suggest you do the same on openvehicles.com.
>>> If no issues turn up, we should aim at the "main" release in about 1-2 weeks.
>>> Summary of changes:
>>> - New vehicle: VW e-Up via OBD-II Port (VWUP.OBD)
>>> - New vehicle: MG ZS EV via OBD-II Port (MGEV)
>>> - New vehicle: BMW i3/i3s via OBD-II Port (BMWI3)
>>> - VW e-Up: combined T26A & OBD module, extended standard metrics coverage,
>>>     charge notifications & durations (OBD), enhanced cabin pre-heating (T26)
>>> - VW e-UP T26A: add climate control and charging detection
>>> - VW e-Up: BMS cell monitoring (@OBD)
>>> - VW e-Up: CCS (DC) charge detection & data
>>>   New metrics:
>>>     xvu.c.ccs.u             -- CCS charger supplied voltage [V]
>>>     xvu.c.ccs.i             -- CCS Charger supplied current [A]
>>>     xvu.c.ccs.p             -- CCS Charger supplied power [kW]
>>> - VW e-Up: replaced MFD range based CAC/SOH by charge coulomb count based
>>>   Removed metrics:
>>>     xvu.b.cap.range
>>>     xvu.b.cap.chg.ah.norm
>>>     xvu.b.cap.chg.kwh.norm
>>>     xvu.b.cap.chg.kwh.abs
>>>   New metrics:
>>>     xvu.b.energy.range      -- MFD range estimation energy [kWh]
>>>     xvu.b.cap.kwh.range     -- … usable battery capacity derived [kWh]
>>>     xvu.b.cap.ah.abs        -- Charge coulomb based capacity [Ah]
>>>     xvu.b.cap.ah.norm       -- … normalized (usable) [Ah]
>>>     xvu.b.cap.kwh.abs       -- Charge energy based capacity [kWh]
>>>     xvu.b.cap.kwh.norm      -- … normalized (usable) [kWh]
>>> - MG ZS EV: Add Charging Metrics page.
>>> - MG ZS EV: Add support for ms_v_charge_kwh, ms_v_bat_energy_used and ms_v_bat_coulomb_used metrics
>>> - Volt/Ampera: BMS cell monitoring (CAN1 polling), fast CAN polling when waking up,
>>>   estimated range gets from CAN instead of calculation,
>>>   lock/unlock status processing fixed for Volt 14MY;
>>>   New standard metrics:
>>>     trip (this charge), energy used (this charge), HV battery capacity (CAC, Ah),
>>>     transmission temp, doors, trunk, hood, lightings;
>>> - Volt/Ampera: new xva metrics:
>>>     xva.v.p.trip.ev   = trip using electric, km;
>>>     xva.v.e.fuel      = fuel tank level, %;
>>> - Renault Twizy: new metrics to reflect extended lock & valet modes:
>>>     xrt.v.e.locked.speed    -- Speed limit [kph] set for Twizy lock mode
>>>     xrt.v.e.valet.odo       -- Odometer limit [km] set for Twizy valet mode
>>> - Renault Twizy: support additional OBD/UDS request types & arguments on "xrt obd request"
>>> - ZOE: BMS cell monitoring (PH1)
>>> - SmartED: add Drivmode for Brabus
>>> - Nissan Leaf: invert batt current sign to match standard metrics definition, populate charger power/efficiency
>>> - Vehicle framework: generic single OBD2/UDS request shell command & API call
>>>   New commands:
>>>     obdii can[1-4] request device [-t<timeout_ms>] [-e] txid rxid request
>>>     obdii can[1-4] request broadcast [-t<timeout_ms>] request
>>> - BMS: optional cell voltage & temperature logging
>>>   New configs:
>>>     [vehicle] bms.log.voltage.interval    Interval [s] for cell voltage logging, default 0=disable
>>>     [vehicle] bms.log.temp.interval       Interval [s] for cell temperature logging, default 0=disable
>>> - BMS: detection of inconsistent voltage series by gradient & stddev average deviation
>>>     thresholds, added pack metrics to battery monitor web UI, change cell warning & alert
>>>     thresholds to be applied exceeding stddev level
>>>   New metrics:
>>>     v.b.p.voltage.grad                    Cell voltage - gradient of current series [V]
>>>   New configs:
>>>     [vehicle] bms.dev.voltage.maxgrad     Max gradient for a valid series
>>>     [vehicle] bms.dev.voltage.maxsddev    Max stddev deviation from average for valid series
>>> - Notifications: added optional long term trip & grid (charge/generator session) server logs.
>>>     See https://docs.openvehicles.com/en/latest/userguide/notifications.html <https://docs.openvehicles.com/en/latest/userguide/notifications.html> for details.
>>>   New configs:
>>>     [notify]  log.trip.storetime    Trip log storage time in days, 0/empty = off (default)
>>>     [notify]  log.trip.minlength    … minimum trip length in km, default 0.2 km
>>>     [notify]  log.grid.storetime    Grid log storage time in days, 0/empty = off (default)
>>> - Metrics: extended reboot persistence: most vehicle state and long term counter
>>>     metrics will now retain their values over a reboot (e.g. OTA update)
>>> - Metrics: new standard metrics for grid integration (V2G) / generator role
>>>     v.c.kwh.grid            Energy drawn from grid during running session
>>>     v.c.kwh.grid.total      Energy drawn from grid total (life time)
>>>     v.g.generating          True = currently delivering power
>>>     v.g.climit              Maximum generator input current (from battery)
>>>     v.g.current             Momentary generator input current (from battery)
>>>     v.g.duration.empty      Estimated time remaining for full discharge
>>>     v.g.duration.range      … for range limit
>>>     v.g.duration.soc        … for SOC limit
>>>     v.g.efficiency          Momentary generator efficiency
>>>     v.g.kwh                 Energy sum generated in the running session
>>>     v.g.kwh.grid            Energy sent to grid during running session
>>>     v.g.kwh.grid.total      Energy sent to grid total
>>>     v.g.limit.range         Minimum range limit for generator mode
>>>     v.g.limit.soc           Minimum SOC limit for generator mode
>>>     v.g.mode                Generator mode (TBD)
>>>     v.g.pilot               Pilot signal present
>>>     v.g.power               Momentary generator output power
>>>     v.g.state               Generator state (TBD)
>>>     v.g.substate            Generator substate (TBD)
>>>     v.g.temp                Generator temperature
>>>     v.g.time                Duration of generator running
>>>     v.g.timermode           True if generator timer enabled
>>>     v.g.timerstart          Time generator is due to start
>>>     v.g.type                Connection type (chademo, ccs, …)
>>>     v.g.voltage             Momentary generator output voltage
>>> - TPMS: metrics rework & standard alert notifications on new v.t.alert metric.
>>>   Replaced metrics…
>>>     v.tp.fl.p               TPMS front left pressure
>>>     v.tp.fl.t               TPMS front left temperature
>>>     v.tp.fr.p               TPMS front right pressure
>>>     v.tp.fr.t               TPMS front right temperature
>>>     v.tp.rl.p               TPMS rear left pressure
>>>     v.tp.rl.t               TPMS rear left temperature
>>>     v.tp.rr.p               TPMS rear right pressure
>>>     v.tp.rr.t               TPMS rear right temperature
>>>   …by…
>>>     v.t.pressure            TPMS tyre pressures vector (fl,fr,rl,rr)
>>>     v.t.temp                TPMS tyre temperatures vector
>>>     v.t.alert               TPMS tyre alert levels [0=normal, 1=warning, 2=alert]
>>>     v.t.health              TPMS tyre health states
>>> - New standard metrics for total (life time) energy and coulomb
>>> - Events: added automatic events on v.e.aux12v changes.
>>>   New events:
>>>     vehicle.aux.12v.on
>>>     vehicle.aux.12v.off
>>> - Location: add metric for name of current location
>>>   New metrics:
>>>     v.p.location        -- Name of current location if defined
>>> - Server V3 improvements:
>>>     a) On first connection to MQTT broker we used to send all metrics. Now
>>>        we only send metrics for which we have a value.
>>>     b) New config settings:
>>>          "updatetime.on" which sets updatetime when the car is on (driving)
>>>          "updatetime.charging" which sets updatetime when the car is charging
>>>          "updatetime.awake" which sets updatetime when the car is awake
>>>        If unset the server uses the "idle" or "connected" interval as before
>>>     c) New config setting "updatetime.sendall". If you set this we will publish
>>>        _all_ valid metrics at this interval. Helpful to keep a steady flow of
>>>        values for charting.
>>>     PLEASE NOTE: These settings will increase OVMS' data usage.
>>> - Wifi: option to immediately disconnect/reconnect on bad signal level
>>>   New config:
>>>     [network] wifi.bad.reconnect [bool], default no
>>> - WiFi: replace fixed scan times by config instances
>>>   New configs:
>>>     [network] wifi.scan.tmin              Min scan time per channel [ms], default 120 ms
>>>     [network] wifi.scan.tmax              Max scan time per channel [ms], default 120 ms
>>> - Updated wolfssh and wolfssl so the restriction of clients to use
>>>   aes128-cbc cipher is no longer required.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210316/87d4a74b/attachment-0001.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210316/87d4a74b/attachment-0001.sig>
