[Ovmsdev] 3.2.016 released to EAP
Mon Mar 8 15:16:15 HKT 2021
I would ask that from now onwards if people want to make changes to the *framework* files, they make them to the for-v3.3 branch (not master). The changes to the framework in v3.3 have been difficult to keep up to date when changes to the master branch files conflict.
Small changes to individual vehicle modules can continue in master, and I will periodically merge master -> for-v3.3 until ready to release. Perhaps after 3.2.016 goes EAP -> MAIN, we can consider merging for-v3.3 into master as it should be ready by then.
The for-v3.3 branch is definitely ok for developers to use now, and I have been running it in my cars for some time.
With my health issues mostly resolved, I am working now on getting v3.3 completed. The foundation is fine, modem -> cellular transition complete, and I am now left with just finalising the plugin system and integration to allow plugins to extend the console commands (no more ’script eval …’ needed).
Thanks, Mark
> On 5 Mar 2021, at 9:30 PM, Michael Balzer <dexter at expeedo.de> wrote:
> Signed PGP part
> Everyone,
> I've just tagged the 3.2.016 release, uploaded it to my "eap" directory and published the info on my site.
> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/releases/tag/3.2.016 <https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/releases/tag/3.2.016>
> https://dexters-web.de/firmware-release-3.2.016-text_98.en.htm <https://dexters-web.de/firmware-release-3.2.016-text_98.en.htm>Mark, I suggest you do the same on openvehicles.com.
> If no issues turn up, we should aim at the "main" release in about 1-2 weeks.
> Summary of changes:
> - New vehicle: VW e-Up via OBD-II Port (VWUP.OBD)
> - New vehicle: MG ZS EV via OBD-II Port (MGEV)
> - New vehicle: BMW i3/i3s via OBD-II Port (BMWI3)
> - VW e-Up: combined T26A & OBD module, extended standard metrics coverage,
>     charge notifications & durations (OBD), enhanced cabin pre-heating (T26)
> - VW e-UP T26A: add climate control and charging detection
> - VW e-Up: BMS cell monitoring (@OBD)
> - VW e-Up: CCS (DC) charge detection & data
>   New metrics:
>     xvu.c.ccs.u             -- CCS charger supplied voltage [V]
>     xvu.c.ccs.i             -- CCS Charger supplied current [A]
>     xvu.c.ccs.p             -- CCS Charger supplied power [kW]
> - VW e-Up: replaced MFD range based CAC/SOH by charge coulomb count based
>   Removed metrics:
>     xvu.b.cap.range
>     xvu.b.cap.chg.ah.norm
>     xvu.b.cap.chg.kwh.norm
>     xvu.b.cap.chg.kwh.abs
>   New metrics:
>     xvu.b.energy.range      -- MFD range estimation energy [kWh]
>     xvu.b.cap.kwh.range     -- … usable battery capacity derived [kWh]
>     xvu.b.cap.ah.abs        -- Charge coulomb based capacity [Ah]
>     xvu.b.cap.ah.norm       -- … normalized (usable) [Ah]
>     xvu.b.cap.kwh.abs       -- Charge energy based capacity [kWh]
>     xvu.b.cap.kwh.norm      -- … normalized (usable) [kWh]
> - MG ZS EV: Add Charging Metrics page.
> - MG ZS EV: Add support for ms_v_charge_kwh, ms_v_bat_energy_used and ms_v_bat_coulomb_used metrics
> - Volt/Ampera: BMS cell monitoring (CAN1 polling), fast CAN polling when waking up,
>   estimated range gets from CAN instead of calculation,
>   lock/unlock status processing fixed for Volt 14MY;
>   New standard metrics:
>     trip (this charge), energy used (this charge), HV battery capacity (CAC, Ah),
>     transmission temp, doors, trunk, hood, lightings;
> - Volt/Ampera: new xva metrics:
>     xva.v.p.trip.ev   = trip using electric, km;
>     xva.v.e.fuel      = fuel tank level, %;
> - Renault Twizy: new metrics to reflect extended lock & valet modes:
>     xrt.v.e.locked.speed    -- Speed limit [kph] set for Twizy lock mode
>     xrt.v.e.valet.odo       -- Odometer limit [km] set for Twizy valet mode
> - Renault Twizy: support additional OBD/UDS request types & arguments on "xrt obd request"
> - ZOE: BMS cell monitoring (PH1)
> - SmartED: add Drivmode for Brabus
> - Nissan Leaf: invert batt current sign to match standard metrics definition, populate charger power/efficiency
> - Vehicle framework: generic single OBD2/UDS request shell command & API call
>   New commands:
>     obdii can[1-4] request device [-t<timeout_ms>] [-e] txid rxid request
>     obdii can[1-4] request broadcast [-t<timeout_ms>] request
> - BMS: optional cell voltage & temperature logging
>   New configs:
>     [vehicle] bms.log.voltage.interval    Interval [s] for cell voltage logging, default 0=disable
>     [vehicle] bms.log.temp.interval       Interval [s] for cell temperature logging, default 0=disable
> - BMS: detection of inconsistent voltage series by gradient & stddev average deviation
>     thresholds, added pack metrics to battery monitor web UI, change cell warning & alert
>     thresholds to be applied exceeding stddev level
>   New metrics:
>     v.b.p.voltage.grad                    Cell voltage - gradient of current series [V]
>   New configs:
>     [vehicle] bms.dev.voltage.maxgrad     Max gradient for a valid series
>     [vehicle] bms.dev.voltage.maxsddev    Max stddev deviation from average for valid series
> - Notifications: added optional long term trip & grid (charge/generator session) server logs.
>     See https://docs.openvehicles.com/en/latest/userguide/notifications.html <https://docs.openvehicles.com/en/latest/userguide/notifications.html> for details.
>   New configs:
>     [notify]  log.trip.storetime    Trip log storage time in days, 0/empty = off (default)
>     [notify]  log.trip.minlength    … minimum trip length in km, default 0.2 km
>     [notify]  log.grid.storetime    Grid log storage time in days, 0/empty = off (default)
> - Metrics: extended reboot persistence: most vehicle state and long term counter
>     metrics will now retain their values over a reboot (e.g. OTA update)
> - Metrics: new standard metrics for grid integration (V2G) / generator role
>     v.c.kwh.grid            Energy drawn from grid during running session
>     v.c.kwh.grid.total      Energy drawn from grid total (life time)
>     v.g.generating          True = currently delivering power
>     v.g.climit              Maximum generator input current (from battery)
>     v.g.current             Momentary generator input current (from battery)
>     v.g.duration.empty      Estimated time remaining for full discharge
>     v.g.duration.range      … for range limit
>     v.g.duration.soc        … for SOC limit
>     v.g.efficiency          Momentary generator efficiency
>     v.g.kwh                 Energy sum generated in the running session
>     v.g.kwh.grid            Energy sent to grid during running session
>     v.g.kwh.grid.total      Energy sent to grid total
>     v.g.limit.range         Minimum range limit for generator mode
>     v.g.limit.soc           Minimum SOC limit for generator mode
>     v.g.mode                Generator mode (TBD)
>     v.g.pilot               Pilot signal present
>     v.g.power               Momentary generator output power
>     v.g.state               Generator state (TBD)
>     v.g.substate            Generator substate (TBD)
>     v.g.temp                Generator temperature
>     v.g.time                Duration of generator running
>     v.g.timermode           True if generator timer enabled
>     v.g.timerstart          Time generator is due to start
>     v.g.type                Connection type (chademo, ccs, …)
>     v.g.voltage             Momentary generator output voltage
> - TPMS: metrics rework & standard alert notifications on new v.t.alert metric.
>   Replaced metrics…
>     v.tp.fl.p               TPMS front left pressure
>     v.tp.fl.t               TPMS front left temperature
>     v.tp.fr.p               TPMS front right pressure
>     v.tp.fr.t               TPMS front right temperature
>     v.tp.rl.p               TPMS rear left pressure
>     v.tp.rl.t               TPMS rear left temperature
>     v.tp.rr.p               TPMS rear right pressure
>     v.tp.rr.t               TPMS rear right temperature
>   …by…
>     v.t.pressure            TPMS tyre pressures vector (fl,fr,rl,rr)
>     v.t.temp                TPMS tyre temperatures vector
>     v.t.alert               TPMS tyre alert levels [0=normal, 1=warning, 2=alert]
>     v.t.health              TPMS tyre health states
> - New standard metrics for total (life time) energy and coulomb
> - Events: added automatic events on v.e.aux12v changes.
>   New events:
>     vehicle.aux.12v.on
>     vehicle.aux.12v.off
> - Location: add metric for name of current location
>   New metrics:
>     v.p.location        -- Name of current location if defined
> - Server V3 improvements:
>     a) On first connection to MQTT broker we used to send all metrics. Now
>        we only send metrics for which we have a value.
>     b) New config settings:
>          "updatetime.on" which sets updatetime when the car is on (driving)
>          "updatetime.charging" which sets updatetime when the car is charging
>          "updatetime.awake" which sets updatetime when the car is awake
>        If unset the server uses the "idle" or "connected" interval as before
>     c) New config setting "updatetime.sendall". If you set this we will publish
>        _all_ valid metrics at this interval. Helpful to keep a steady flow of
>        values for charting.
>     PLEASE NOTE: These settings will increase OVMS' data usage.
> - Wifi: option to immediately disconnect/reconnect on bad signal level
>   New config:
>     [network] wifi.bad.reconnect [bool], default no
> - WiFi: replace fixed scan times by config instances
>   New configs:
>     [network] wifi.scan.tmin              Min scan time per channel [ms], default 120 ms
>     [network] wifi.scan.tmax              Max scan time per channel [ms], default 120 ms
> - Updated wolfssh and wolfssl so the restriction of clients to use
>   aes128-cbc cipher is no longer required.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210308/f2dfb311/attachment-0001.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210308/f2dfb311/attachment-0001.sig>
