[Ovmsdev] DTC code reading
Sun Jun 20 19:54:16 HKT 2021
That log file is missing too many frames to be readable, and the logger
should have told you that.
Maybe your OVMS has an SD speed issue? Have you tried raising the
optimization hints?
https://docs.openvehicles.com/en/latest/crtd/can_logging.html#optimizing-the-performance
Anyway, it seems your tool queries at least the four ECUs defined in the
source. It uses diag session 0x92 (i.e. request 1092), and then request
1800ff00 to retrieve the DTCs.
18 is not a standard UDS command, but some VW ECUs (especially the TP2.0
ones) also use this (but there it's 1802ff00).
You can try other subfunctions, i.e. 1801, 1802, etc. to see if you get
something else than "subfunction not supported".
To clear the DTCs, the tool seems to use the standard command 14, but
with non-standard parameters: the log has a request 14ff00 to 771 (but
the response is missing).
Due to the missing frames, your DTCs are not readable in the log. Try to
get a log without dropped frames.
Am 20.06.21 um 09:02 schrieb Tamás Kovács:
> a) a test with another two device
> b) nothing working
> c) if i use 19 Poll type and vehicle set to trio no response, if
> vehicle empty set get 80-error code
> If i connect simultaneously another device can i capture the DTC code
> reading with ovms using a Y OBD cable?
> My car always have a U1113 DTC error because not have a EV-REMOTE ECU.
> I have a log file created with ovms when i read and clean the dtc
> codes with hobdrive. Another error codes: P1A39 (BMU), P1A33 (BMU),
> P1A7E (CMU)
> Log file:
> https://drive.google.com/file/d/1zcIcMsBYLEoubafO1P6JW_GchZXI7WLD/view?usp=sharing
> <https://drive.google.com/file/d/1zcIcMsBYLEoubafO1P6JW_GchZXI7WLD/view?usp=sharing>
> Michael Balzer <dexter at expeedo.de <mailto:dexter at expeedo.de>> ezt írta
> (időpont: 2021. jún. 19., Szo, 18:55):
> Tamás,
> a) are you sure the DTC is in device 761/762? There are three more
> devices in the i-MiEV source.
> b) maybe you need to give another status mask, e.g. 1902ae or just
> all DTCs by 1902ff -- did you try that?
> c) you can also try the other DTC retrieval subfunctions, e.g.
> 1901<mask> to get just the number of DTCs (see ISO spec for more)
> Am 19.06.21 um 18:13 schrieb Tamás Kovács:
>> Hi!
>> I would like to create a dtc reading on i-miEV/ Peugeot iOn. But
>> if is send the following command:
>> OVMS#obd can1 request device 761 762 19020f
>> 761[762] 19020f: request failed with response error code 80
>> I now use hobdrive app to read dtc code with OBDlink LX
> OvmsDev at lists.openvehicles.com <mailto:OvmsDev at lists.openvehicles.com>
> <http://lists.openvehicles.com/mailman/listinfo/ovmsdev>
> Üdvözlettel:
> Kovács Tamás
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210620/b0a4eaec/attachment.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210620/b0a4eaec/attachment.sig>
