[Ovmsdev] DTC code reading
    Tamás Kovács
    kommykt at gmail.com
    Mon Jun 21 14:41:19 HKT 2021
Now i create a new log file without dropped frame, with filter.
https://drive.google.com/file/d/1o477jmllYyntpmLJca_3aTmL2NvYZfsZ/view?usp=sharing
Only active error code is U1113.
This is a U1113 Error?
1624253728.207555 1R11 751 04 18 00 ff 00 00 00 00
1624253728.213037 1R11 752 05 58 01 d1 13 e0 00 8e
OVMS# obd can1 request device 751 752 1800ff00
751[752] 1800ff00: Response: 01 d1 13 e0                 | ....
if i decode this
d1 = 11010001
bit 6-7 = 11 -» U
bit 4-5 = 01 -» 1
bit 0-3 = 0001 -» 1
 so the error code is: U1113
OVMS# obd can1 request device 751 752 1801ff00
751[752] 1801ff00: Response:
df 05 62 00 00 b4 00 00 b3 00 21 23 00 21 22 00 | ..b.......!#.!".
1a 00 00 21 28 00 21 27 00 1a 01 00 21 38 00 05 | ...!(.!'....!8..
58 00 05 57 00 1b 31 00 1a f0 00 1b 19 00 1b 1a | X..W..1.........
00 1b 1b 00 28 05 00 07 05 00 1a 02 00 1a 03 00 | ....(...........
1a 04 00 1a 2c 00 1a 06 00 1a 07 00 1a 08 00 1a | ....,...........
09 00 1a 0a 00 1a 0b 00 1a 0c 00 1a 0d 00 1a 0e | ................
00 1a 0f 00 0c 73 00 0c 74 00 0a 05 00 1b 2b 00 | .....s..t.....+.
06 91 00 06 92 00 06 93 00 06 94 00 0a 01 00 1a | ................
10 00 1a 11 00 1a 12 00 06 46 00 06 47 00 d8 01 | .........F..G...
00 d8 02 00 d8 03 00 d8 04 00 d8 05 00 d8 06 00 | ................
1a 14 00 1b 0a 00 0a e6 00 0a e7 00 0a e2 00 0a | ................
db 00 0a a1 00 0a df 00 0a a4 00 0a 0a 00 1a 15 | ................
00 1a 16 00 1a 17 00 0a 09 00 0a 10 00 1b 29 00 | ..............).
1b 2a 00 1a 18 00 1a 19 00 06 0b 00 06 05 00 06 | .*..............
04 00 06 0c 00 16 02 00 06 2f 00 d1 90 00 d0 73 | ........./.....s
00 1b 09 00 d1 1b 00 d1 1c 00 d1 1d 00 d1 10 00 | ................
d1 02 00 d1 04 00 1b 35 00 d1 08 00 d1 09 00 d1 | .......5........
05 00 1b 36 00 d1 13 e0 d1 06 00 d1 6a 00 d1 6b | ...6........j..k
00 d9 10 00 d9 00 00 d9 11 00 d9 01 00 1a 1a 00 | ................
1a f1 00 1a f2 00 1a f3 00 05 60 00 1a 1b 00 1a | ..........`.....
1c 00 1a 22 00 1a 1e 00 d0 80 00 d1 60 00 d9 20 | ..."........`..
00 0a ba 00 1a 1f 00 0a 2a 00 0a 3d 00 0a ed 00 | ........*..=....
0a 51 00 1a 20 00 1a 21 00 1a 23 00 1a 24 00 1a | .Q.. ..!..#..$..
25 00 1a 26 00 1a 27 00 1a 28 00 1a 29 00 1a 2a | %..&..'..(..)..*
00 0a 90 00 0a 78 00 1a 2b 00 1a 3d 00 1a 3e 00 | .....x..+..=..>.
1a 3f 00 1b 1c 00 1b 1d 00 0a bf 00 1a 44 00 1a | .?...........D..
45 00 1a 2d 00 1a 2e 00 1a 2f 00 1a 30 00 1a 31 | E..-...../..0..1
00 1a 32 00 1b 33 00 1a 33 00 1a 34 00 1b 34 00 | ..2..3..3..4..4.
1a 35 00 1a e6 00 d0 81 00 d1 61 00 d0 90 00 1a | .5........a.....
38 00 d9 21 00 d9 24 00 1a f4 00 1a f5 00 1a 39 | 8..!..$........9
00 1b 1e 00 1b 1f 00 1a c5 00 1b 2f 00 1b 21 00 | .........../..!.
1a f6 00 1a f7 00 1a f8 00 1a f9 00 1a fa 00 1a | ................
fb 00 1a fc 00 1a fd 00 1a fe 00 1a ff 00 1b 00 | ................
00 1b 01 00 1b 02 00 1b 03 00 1b 04 00 1b 05 00 | ................
1b 06 00 1b 07 00 1b 08 00 1b 0c 00 1b 0d 00 1b | ................
0b 00 1b 22 00 1b 23 00 1b 24 00 1b 25 00 1b 26 | ..."..#..$..%..&
00 1b 27 00 1b 28 00 1b 2c 00 1b 30 00 1b 2d 00 | ..'..(..,..0..-.
1b 32 00 d1 17 00 05 13 00 12 31 00 1b 37 00 91 | .2........1..7..
78 00 60 05 00 60 06 00 60 07 00 60 0a 00 60 0e | x.`..`..`..`..`.
00 60 0f 00 60 10 00 60 11 00 60 16 00 60 18 00 | .`..`..`..`..`..
60 19 00 60 1a 00 60 20 00 60 21 00 60 22 00 60 | `..`..` .`!.`".`
2a 00 60 2b 00 60 2c 00 60 2d 00 60 2e 00       | *.`+.`,.`-.`..
OVMS# obd can1 request device 751 752 1802ff00
751[752] 1802ff: ERROR: request failed with response error code 12
subFunctionNotSupported
This is clear of dtc codes?
1624253725.617633 1R11 751 03 14 ff 00 00 00 00 00
1624253725.618253 1R11 752 03 54 ff 00 13 e0 00 8e
Michael Balzer <dexter at expeedo.de> ezt írta (időpont: 2021. jún. 20., V,
13:54):
> That log file is missing too many frames to be readable, and the logger
> should have told you that.
> Maybe your OVMS has an SD speed issue? Have you tried raising the
> optimization hints?
> https://docs.openvehicles.com/en/latest/crtd/can_logging.html#optimizing-the-performance
> Anyway, it seems your tool queries at least the four ECUs defined in the
> source. It uses diag session 0x92 (i.e. request 1092), and then request
> 1800ff00 to retrieve the DTCs.
> 18 is not a standard UDS command, but some VW ECUs (especially the TP2.0
> ones) also use this (but there it's 1802ff00).
> You can try other subfunctions, i.e. 1801, 1802, etc. to see if you get
> something else than "subfunction not supported".
> To clear the DTCs, the tool seems to use the standard command 14, but with
> non-standard parameters: the log has a request 14ff00 to 771 (but the
> response is missing).
> Due to the missing frames, your DTCs are not readable in the log. Try to
> get a log without dropped frames.
> Am 20.06.21 um 09:02 schrieb Tamás Kovács:
> a) a test with another two device
> b) nothing working
> c) if i use 19 Poll type and vehicle set to trio no response, if
> vehicle empty set get 80-error code
> If i connect simultaneously another device can i capture the DTC code
> reading with ovms using a Y OBD cable?
> My car always have a U1113 DTC error because not have a EV-REMOTE ECU. I
> have a log file created with ovms when i read and clean the dtc codes with
> hobdrive. Another error codes: P1A39 (BMU), P1A33 (BMU), P1A7E (CMU)
> Log file:
> https://drive.google.com/file/d/1zcIcMsBYLEoubafO1P6JW_GchZXI7WLD/view?usp=sharing
> Michael Balzer <dexter at expeedo.de> ezt írta (időpont: 2021. jún. 19.,
> Szo, 18:55):
>> Tamás,
>> a) are you sure the DTC is in device 761/762? There are three more
>> devices in the i-MiEV source.
>> b) maybe you need to give another status mask, e.g. 1902ae or just all
>> DTCs by 1902ff -- did you try that?
>> c) you can also try the other DTC retrieval subfunctions, e.g. 1901<mask>
>> to get just the number of DTCs (see ISO spec for more)
>> Am 19.06.21 um 18:13 schrieb Tamás Kovács:
>> Hi!
>> I would like to create a dtc reading on i-miEV/ Peugeot iOn. But if is
>> send the following command:
>> OVMS# obd can1 request device 761 762 19020f
>> 761[762] 19020f: request failed with response error code 80
>> I now use hobdrive app to read dtc code with OBDlink LX
> Üdvözlettel:
> Kovács Tamás
> OvmsDev mailing listOvmsDev at lists.openvehicles.comhttp://lists.openvehicles.com/mailman/listinfo/ovmsdev
Üdvözlettel:
Kovács Tamás
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210621/d36021d0/attachment.htm>
