[Ovmsdev] DTC code reading
Tamás Kovács
kommykt at gmail.com
Sun Jun 20 15:02:42 HKT 2021
a) a test with another two device
b) nothing working
c) if i use 19 Poll type and vehicle set to trio no response, if
vehicle empty set get 80-error code
If i connect simultaneously another device can i capture the DTC code
reading with ovms using a Y OBD cable?
My car always have a U1113 DTC error because not have a EV-REMOTE ECU. I
have a log file created with ovms when i read and clean the dtc codes with
hobdrive. Another error codes: P1A39 (BMU), P1A33 (BMU), P1A7E (CMU)
Log file:
https://drive.google.com/file/d/1zcIcMsBYLEoubafO1P6JW_GchZXI7WLD/view?usp=sharing
Michael Balzer <dexter at expeedo.de> ezt írta (időpont: 2021. jún. 19., Szo,
18:55):
> Tamás,
> a) are you sure the DTC is in device 761/762? There are three more devices
> in the i-MiEV source.
> b) maybe you need to give another status mask, e.g. 1902ae or just all
> DTCs by 1902ff -- did you try that?
> c) you can also try the other DTC retrieval subfunctions, e.g. 1901<mask>
> to get just the number of DTCs (see ISO spec for more)
> Am 19.06.21 um 18:13 schrieb Tamás Kovács:
> Hi!
> I would like to create a dtc reading on i-miEV/ Peugeot iOn. But if is
> send the following command:
> OVMS# obd can1 request device 761 762 19020f
> 761[762] 19020f: request failed with response error code 80
> I now use hobdrive app to read dtc code with OBDlink LX
Üdvözlettel:
Kovács Tamás
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210620/a9d4d4d4/attachment.htm>
