[Ovmsdev] Fwd: How does TPMS work now?
Tue Jan 26 06:11:20 HKT 2021
sharkcow,
the "number" metric widget cannot handle vectors currently. The "chart"
and "table" widgets can, but need a little bit more initialization work
(see examples … a simple table example may still be missing, I can
create one if needed).
You can also register an event handler for "msg:metrics" and fill your
fields directly. Or extend the "metric number" widget to support vector
metrics.
A bar chart would visualize the relative tyre states nicely. You could
set the wheel names as category (X axis) labels and add the alerts as a
second series or colorize the bars by it (as I do with the BMS chart).
Am 25.01.21 um 22:34 schrieb sharkcow:
> Michael,
> thanks for your extensive response.
> Regarding the WebPlugin, I seem to be lost... I just get the ol'
> question mark if I use this:
>     <div class="metric number" data-metric=metrics["v.t.health"][0]>
>      <span class="label">Tyre Health FL</span>
>      <span class="value">?</span>
>      <span class="unit"></span>
>     </div>
> Tried all sorts of combinations with the quotes too... in the shell the
> metric is valid:
> v.t.health 97.2549,97.2549,100,97.2549%
> What am I missing?
> Thanks!
> sharkcow
> Am 25.01.21 um 12:59 schrieb Michael Balzer:
>> sharkcow,
>> the metrics shell command currently only supports getting & setting full
>> values, i.e. all values at once on a vector metric.
>> Workaround: use Javascript:
>> sc ev 'm="v.t.health"; v=OvmsMetrics.Value(m); v[2]=80;
>> OvmsCommand.Exec("met set "+m+" "+v);'
>> Not very handy that way. You can define a function for that in your
>> ovmsmain.js:
>> function metricSetElem(metric, index, value) {
>>    vector = OvmsMetrics.Value(metric);
>>    vector[index] = value;
>> OvmsCommand.Exec("metric set " + metric + " " + vector);
>> …and then call it like this:
>> sc ev 'metricSetElem("v.t.health", 2, 80)'
>> Or you could add support to address single vector elements to the
>> "metric" command.
>> OTOH, setting a metric manually is normally only needed during
>> development though, so you already have artificial test values, why not
>> simply set the whole vector?
>> Regarding reading vector metrics in a web plugin, that's straight
>> forward: the vector is stored as an array in the global metrics object.
>> Addressing elements is as simple as…
>> metrics["v.t.health"][2]
>> …and of course you can do everything you normally can do with an array.
>> Setting metric values from the web UI isn't a standard operation, so you
>> need to call the "metrics" command for that here as well, e.g. via
>> loadcmd().
>> Am 25.01.21 um 09:07 schrieb sharkcow:
>>> Hello all,
>>> probably this is a stupid question, but can I set/read individual
>>> elements of an array on the command line? More importantly, is there a
>>> way to access individual elements in WebPlugins (I know I could write a
>>> script, but that seems to be overkill and I'd first have to find out
>>> exactly how to do it :-/)
>>> Thanks!
>>> sharkcow
>>> Am 23.01.21 um 18:22 schrieb Michael Balzer:
>>>> It seems the list server still has issues:
>>>> -------- Weitergeleitete Nachricht --------
>>>> Betreff:     Re: [Ovmsdev] How does TPMS work now?
>>>> Datum:     Mon, 18 Jan 2021 07:54:31 +0100
>>>> Von:     Michael Balzer <dexter at expeedo.de>
>>>> An:     ovmsdev at lists.openvehicles.com
>>>> Craig,
>>>> vector metrics can (as all metrics btw) be set by their string
>>>> representation, i.e.
>>>> metrics set v.t.pressure 210.29,210.29,210.29,210.29
>>>> …and all TPMS metrics (also the new ones) are persistent now, see my
>>>> post "extended metrics persistence".
>>>> Regarding the sensor sets, I haven't used them yet, and
>>>> documentation is
>>>> lacking, so you need to check the source.
>>>> Regards,
>>>> Michael
>>>> Am 18.01.21 um 04:11 schrieb Craig Leres:
>>>>> It used to be possible to manually set tire pressure with:
>>>>>     metrics set v.tp.fl.p 210.29
>>>>>     metrics set v.tp.fr.p 210.29
>>>>>     metrics set v.tp.rl.p 210.29
>>>>>     metrics set v.tp.rr.p 210.29
>>>>> but after upgrading to the latest persistent metrics code I see these
>>>>> are all gone.
>>>>> I looked at the tpms command but it seems to be designed to track
>>>>> different sets of tpms sensor id numbers.
>>>>> Is it possible to set these from the command line? Are tpms tire
>>>>> pressures (and temperatures) still persistent across warm reboots? Is
>>>>> my problem that these are stored in vectors now and there is not
>>>>> yet a
>>>>> way to manipulate them from the command line?
>>>>>         Craig
>>>>> OvmsDev mailing list
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210125/fa614f78/attachment.sig>
