[Ovmsdev] Fwd: How does TPMS work now?
Wed Jan 27 05:59:12 HKT 2021
I've created a simple metric table example -- and found an old bug in
the update code by doing so :-)
IOW, update before trying the example:
https://docs.openvehicles.com/en/latest/components/ovms_webserver/docs/metrics.html#vector-tables
Am 25.01.21 um 23:11 schrieb Michael Balzer:
> sharkcow,
> the "number" metric widget cannot handle vectors currently. The
> "chart" and "table" widgets can, but need a little bit more
> initialization work (see examples … a simple table example may still
> be missing, I can create one if needed).
> You can also register an event handler for "msg:metrics" and fill your
> fields directly. Or extend the "metric number" widget to support
> vector metrics.
> A bar chart would visualize the relative tyre states nicely. You could
> set the wheel names as category (X axis) labels and add the alerts as
> a second series or colorize the bars by it (as I do with the BMS chart).
> Am 25.01.21 um 22:34 schrieb sharkcow:
>> Michael,
>> thanks for your extensive response.
>> Regarding the WebPlugin, I seem to be lost... I just get the ol'
>> question mark if I use this:
>>     <div class="metric number" data-metric=metrics["v.t.health"][0]>
>>      <span class="label">Tyre Health FL</span>
>>      <span class="value">?</span>
>>      <span class="unit"></span>
>>     </div>
>> Tried all sorts of combinations with the quotes too... in the shell the
>> metric is valid:
>> v.t.health 97.2549,97.2549,100,97.2549%
>> What am I missing?
>> Thanks!
>> sharkcow
>> Am 25.01.21 um 12:59 schrieb Michael Balzer:
>>> sharkcow,
>>> the metrics shell command currently only supports getting & setting
>>> full
>>> values, i.e. all values at once on a vector metric.
>>> Workaround: use Javascript:
>>> sc ev 'm="v.t.health"; v=OvmsMetrics.Value(m); v[2]=80;
>>> OvmsCommand.Exec("met set "+m+" "+v);'
>>> Not very handy that way. You can define a function for that in your
>>> ovmsmain.js:
>>> function metricSetElem(metric, index, value) {
>>>    vector = OvmsMetrics.Value(metric);
>>>    vector[index] = value;
>>> OvmsCommand.Exec("metric set " + metric + " " + vector);
>>> …and then call it like this:
>>> sc ev 'metricSetElem("v.t.health", 2, 80)'
>>> Or you could add support to address single vector elements to the
>>> "metric" command.
>>> OTOH, setting a metric manually is normally only needed during
>>> development though, so you already have artificial test values, why not
>>> simply set the whole vector?
>>> Regarding reading vector metrics in a web plugin, that's straight
>>> forward: the vector is stored as an array in the global metrics object.
>>> Addressing elements is as simple as…
>>> metrics["v.t.health"][2]
>>> …and of course you can do everything you normally can do with an array.
>>> Setting metric values from the web UI isn't a standard operation, so
>>> you
>>> need to call the "metrics" command for that here as well, e.g. via
>>> loadcmd().
>>> Am 25.01.21 um 09:07 schrieb sharkcow:
>>>> Hello all,
>>>> probably this is a stupid question, but can I set/read individual
>>>> elements of an array on the command line? More importantly, is there a
>>>> way to access individual elements in WebPlugins (I know I could
>>>> write a
>>>> script, but that seems to be overkill and I'd first have to find out
>>>> exactly how to do it :-/)
>>>> Thanks!
>>>> sharkcow
>>>> Am 23.01.21 um 18:22 schrieb Michael Balzer:
>>>>> It seems the list server still has issues:
>>>>> -------- Weitergeleitete Nachricht --------
>>>>> Betreff:     Re: [Ovmsdev] How does TPMS work now?
>>>>> Datum:     Mon, 18 Jan 2021 07:54:31 +0100
>>>>> Von:     Michael Balzer <dexter at expeedo.de>
>>>>> An:     ovmsdev at lists.openvehicles.com
>>>>> Craig,
>>>>> vector metrics can (as all metrics btw) be set by their string
>>>>> representation, i.e.
>>>>> metrics set v.t.pressure 210.29,210.29,210.29,210.29
>>>>> …and all TPMS metrics (also the new ones) are persistent now, see my
>>>>> post "extended metrics persistence".
>>>>> Regarding the sensor sets, I haven't used them yet, and
>>>>> documentation is
>>>>> lacking, so you need to check the source.
>>>>> Regards,
>>>>> Michael
>>>>> Am 18.01.21 um 04:11 schrieb Craig Leres:
>>>>>> It used to be possible to manually set tire pressure with:
>>>>>>     metrics set v.tp.fl.p 210.29
>>>>>>     metrics set v.tp.fr.p 210.29
>>>>>>     metrics set v.tp.rl.p 210.29
>>>>>>     metrics set v.tp.rr.p 210.29
>>>>>> but after upgrading to the latest persistent metrics code I see
>>>>>> these
>>>>>> are all gone.
>>>>>> I looked at the tpms command but it seems to be designed to track
>>>>>> different sets of tpms sensor id numbers.
>>>>>> Is it possible to set these from the command line? Are tpms tire
>>>>>> pressures (and temperatures) still persistent across warm
>>>>>> reboots? Is
>>>>>> my problem that these are stored in vectors now and there is not
>>>>>> yet a
>>>>>> way to manipulate them from the command line?
>>>>>>         Craig
>>>>>> OvmsDev mailing list
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210126/948534ed/attachment-0001.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210126/948534ed/attachment-0001.sig>
