[Ovmsdev] Fwd: How does TPMS work now?
    sharkcow
    sharkcow at gmx.de
    Tue Jan 26 05:34:46 HKT 2021
Michael,
thanks for your extensive response.
Regarding the WebPlugin, I seem to be lost... I just get the ol'
question mark if I use this:
     <div class="metric number" data-metric=metrics["v.t.health"][0]>
      <span class="label">Tyre Health FL</span>
      <span class="value">?</span>
      <span class="unit"></span>
     </div>
Tried all sorts of combinations with the quotes too... in the shell the
metric is valid:
v.t.health                               97.2549,97.2549,100,97.2549%
What am I missing?
Thanks!
sharkcow
Am 25.01.21 um 12:59 schrieb Michael Balzer:
> sharkcow,
> the metrics shell command currently only supports getting & setting full
> values, i.e. all values at once on a vector metric.
> Workaround: use Javascript:
> sc ev 'm="v.t.health"; v=OvmsMetrics.Value(m); v[2]=80;
> OvmsCommand.Exec("met set "+m+" "+v);'
> Not very handy that way. You can define a function for that in your
> ovmsmain.js:
> function metricSetElem(metric, index, value) {
>    vector = OvmsMetrics.Value(metric);
>    vector[index] = value;
> OvmsCommand.Exec("metric set " + metric + " " + vector);
> …and then call it like this:
> sc ev 'metricSetElem("v.t.health", 2, 80)'
> Or you could add support to address single vector elements to the
> "metric" command.
> OTOH, setting a metric manually is normally only needed during
> development though, so you already have artificial test values, why not
> simply set the whole vector?
> Regarding reading vector metrics in a web plugin, that's straight
> forward: the vector is stored as an array in the global metrics object.
> Addressing elements is as simple as…
> metrics["v.t.health"][2]
> …and of course you can do everything you normally can do with an array.
> Setting metric values from the web UI isn't a standard operation, so you
> need to call the "metrics" command for that here as well, e.g. via
> loadcmd().
> Am 25.01.21 um 09:07 schrieb sharkcow:
>> Hello all,
>> probably this is a stupid question, but can I set/read individual
>> elements of an array on the command line? More importantly, is there a
>> way to access individual elements in WebPlugins (I know I could write a
>> script, but that seems to be overkill and I'd first have to find out
>> exactly how to do it :-/)
>> Thanks!
>> sharkcow
>> Am 23.01.21 um 18:22 schrieb Michael Balzer:
>>> It seems the list server still has issues:
>>> -------- Weitergeleitete Nachricht --------
>>> Betreff:     Re: [Ovmsdev] How does TPMS work now?
>>> Datum:     Mon, 18 Jan 2021 07:54:31 +0100
>>> Von:     Michael Balzer <dexter at expeedo.de>
>>> An:     ovmsdev at lists.openvehicles.com
>>> Craig,
>>> vector metrics can (as all metrics btw) be set by their string
>>> representation, i.e.
>>> metrics set v.t.pressure 210.29,210.29,210.29,210.29
>>> …and all TPMS metrics (also the new ones) are persistent now, see my
>>> post "extended metrics persistence".
>>> Regarding the sensor sets, I haven't used them yet, and documentation is
>>> lacking, so you need to check the source.
>>> Am 18.01.21 um 04:11 schrieb Craig Leres:
>>>> It used to be possible to manually set tire pressure with:
>>>>     metrics set v.tp.fl.p 210.29
>>>>     metrics set v.tp.fr.p 210.29
>>>>     metrics set v.tp.rl.p 210.29
>>>>     metrics set v.tp.rr.p 210.29
>>>> but after upgrading to the latest persistent metrics code I see these
>>>> are all gone.
>>>> I looked at the tpms command but it seems to be designed to track
>>>> different sets of tpms sensor id numbers.
>>>> Is it possible to set these from the command line? Are tpms tire
>>>> pressures (and temperatures) still persistent across warm reboots? Is
>>>> my problem that these are stored in vectors now and there is not yet a
>>>> way to manipulate them from the command line?
>>>>         Craig
>>>> OvmsDev mailing list
