[Ovmsdev] GPS quits?
Tue Jan 12 20:46:46 HKT 2021
Steve,
a) did you pick an active GPS antenna? I.e. one with a voltage on the
label. The module can barely get a signal with passive antennas.
b) If you restart the modem, wait for "State: PoweredOff" before
starting it again.
c) You can monitor the NMEA sentences by setting log level verbose gsm-nmea.
d) Not getting PPP as well may point to a general modem issue, maybe
also log gsm-mux & simcom to check for that.
Am 12.01.21 um 11:05 schrieb Steve Davies:
> Hi,
> I'm finding the OVMS GPS really unreliable.
> For instance, here are the current "v.p." values from my OVMS.
> I'm apparently going 88 km/h on the highway notwithstanding that my
> car is parked at my house:
>     v.p.acceleration
>     v.p.altitude       9.7m
>     v.p.direction        347.5°
>     v.p.gpshdop        1
>     v.p.gpslock        yes
>     v.p.gpsmode        AN
>     v.p.gpsspeed       88.3404km/h
>     v.p.latitude       -34.0584
>     v.p.location
>     v.p.longitude        18.4477
>     v.p.odometer       15053km
>     v.p.satcount       9
>     v.p.speed        0km/h
>     v.p.trip       22km
>     xi3.v.p.tripconsumption        125Wh/km
>     xi3.v.p.wheel1_speed       0km/h
>     xi3.v.p.wheel2_speed       0km/h
>     xi3.v.p.wheel3_speed       0km/h
>     xi3.v.p.wheel4_speed       0km/h
>     xi3.v.p.wheel_speed        0km/h
> Earlier when I went out the GPS position got similarly stuck and only
> recovered when I power cycled the OVMS.
> simcom status:
>     OVMS# simcom status
>     Network Registration: RegisteredHome
>     Provider: VodaCom-SA
>     Signal: -99 dBm
>     State: NetMode
>     PPP: Connected on channel: #2
>     GPS: Connected on channel: #1
> I turned the modem off with the gui and then turned it on.  Result of
> doing that was it did not get a PPP connection after some minutes, and
> the GPS did not connect.
> I tried this twice with the same result.  Position is still the old
> one as above, no 3G PPP connection and no GPS connection.
> My GPS antenna is currently on the dashboard - could it be overheating
> in the sun there? - it is probably pretty warm.  (But my car is
> currently under shade since I got home)
> I now went and power cycled the OVMS and the SIMCOM connected
> successfully, GPS connected, and has the correct position:
> OVMS# metrics list v.p.
> v.p.acceleration
> v.p.altitude                             5.2m
> v.p.direction                            0°
> v.p.gpshdop                              1
> v.p.gpslock                              yes
> v.p.gpsmode                              AA
> v.p.gpsspeed                             0km/h
> v.p.latitude                             -34.0XXX
> v.p.location                             Home
> v.p.longitude                            18.4XXX
> v.p.satcount                             9
> v.p.speed                                0km/h
> v.p.trip                                 22km
> I'm running with the ABRP script - is it possible that this is
> impacting the reliability?
> Otherwise I'm looking for ideas...
> Thanks,
> Steve
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210112/934d2c46/attachment-0001.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210112/934d2c46/attachment-0001.sig>
