[Ovmsdev] GPS location glitch (flatbed theft false alert)
Tue Aug 17 17:09:48 HKT 2021
On the e-Up / Mii / Go, we still occasionally (seldom) get a false
flatbed alert.
I've tracked this down to our "vehicle is on" heuristic, which is
currently taking the 12V level as an indicator. That turns out to be
unreliable: in the cases of the false alerts, the DC converter output
did not rise above 13.1V, which is normal "awake" level.
The "vehicle.on" event is necessary for the GPS logic to recognize the
car is about to drive, i.e. leaving the parking position. Without the
event, the location module sees movement while still assuming parking.
So in case you still get these false alerts, enable event logging and
check if your car reliably emits "vehicle.on".
PS: @UpMiiGo crew: I'll test some other options for our vehicle.on logic.
Am 30.06.21 um 19:39 schrieb Craig Leres:
> On 6/30/21 1:05 AM, Michael Balzer wrote:
>>> Another (possibly far fetched) idea I had was is it possible we'
>>> seeing corruption transferring the gps location from the simcom to
>>> the esp32? A race condition where the latitude or the longitude gets
>>> clobbered while reading it? I don't have a good idea of what other
>>> symptoms that kind of problem would have.
>> Actually… not far fetched at all, as we continuously see multiplex
>> frame errors in the logs -- see my previous posts on this. We don't
>> have flow control on the ESP-SIMCOM serial line, and the handler may
>> not catch all losses.
>> You can test that theory by enabling the verbose log on "gsm-nmea".
>> Be aware that's a lot of log messages.
>> Better option: I already do some consistency checks in
>> GsmNMEA::IncomingLine(), but I didn't implement the NMEA checksum.
>> You might give that a try first.
> Ooooh NMEA... Yeah, if we're getting errors there I can guess where
> the 0.0's are coming from; gps2latlon() uses atof() so if the field it
> tries to parse is empty or is a non-numeric, it'll return 0.0.
> I'll spend some time looking at that module, at a minimum implementing
> the checksum is worth doing.
> Craig
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210817/b4e869c7/attachment.sig>
