[Ovmsdev] Duktape JSON vs. CBOR serialization performance
Sat Aug 28 22:34:45 HKT 2021
Everyone,
when debugging some lost events due to Duktape queue overflows, I
stumbled across a major Duktape performance issue in the JSON
serialization support: encoding the AuxBatMon history data object of 5
arrays with 1440 numbers each (JSON size ~ 30 K) took ~ 12 seconds.
I searched the Duktape repository for this and found a "fastpath"
optimization we can use but didn't enable, so I tried that: that took
down the encoding time to ~ 8 seconds. Unfortunately, that's as good as
it gets with JSON in Duktape.
So I checked the CBOR support
(https://duktape.org/guide.html#builtin-cbor), and that works much
better. Encoding the AuxBatMon history to CBOR takes ~ 500 ms. That's
still not really good, but acceptable.
To enable using CBOR for data exchange with the web frontend as well,
I've included the CBOR-JS library by Patrick Gansterer, and added a
binary output option for Javascript commands. I've changed the AuxBatMon
and PwrMon plugins to use CBOR instead of JSON, and both work and load
much faster now.
I strongly suggest updating the plugins if you use them.
If you implement a plugin with some kind of data storage or transfer of
larger objects to the web frontend, do not use JSON, use CBOR instead.
I've added a section to our manual on this:
https://docs.openvehicles.com/en/latest/userguide/scripting.html#cbor
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210828/59eb7e19/attachment.sig>
