[Ovmsdev] OVMS going comatose
Sun Apr 11 15:44:56 HKT 2021
Steve,
I can confirm an increase of these events since we changed to WolfSSL,
about once every three days currently for me. The frequency was much
lower before, more like once or twice per month.
I've disabled TLS on my module now and will report if that helps.
Am 10.04.21 um 21:20 schrieb Stephen Casner:
> Michael,
> As you saw from my earlier emails, I was getting these crashes
> typically after less than 24 hours of operation. I changed my config
> to disable TLS on server v2 and rebooted 2021-04-05 23:36:04.648 PDT
> and there has not been a crash since. So it definitely appears to be
> correlated with the additional processing to support TLS.
> -- Steve
> On Sun, 4 Apr 2021, Michael Balzer wrote:
>> Steve,
>> that's the problem with this issue, it's totally unclear what causes this.
>> The signal dropping begins when the queue is full, which happens after the
>> task has been blocked for ~as many seconds as the queue is big. So there is no
>> logged activity that could cause this, your module basically went into this
>> from idling.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210411/8ebe8965/attachment.sig>
