[Ovmsdev] OVMS going comatose
Sun Apr 11 03:20:25 HKT 2021
Michael,
As you saw from my earlier emails, I was getting these crashes
typically after less than 24 hours of operation.  I changed my config
to disable TLS on server v2 and rebooted 2021-04-05 23:36:04.648 PDT
and there has not been a crash since.  So it definitely appears to be
correlated with the additional processing to support TLS.
On Sun, 4 Apr 2021, Michael Balzer wrote:
> Steve,
> that's the problem with this issue, it's totally unclear what causes this.
> The signal dropping begins when the queue is full, which happens after the
> task has been blocked for ~as many seconds as the queue is big. So there is no
> logged activity that could cause this, your module basically went into this
> from idling.
