[Ovmsdev] ssl cert
Thu Apr 1 16:10:50 HKT 2021
You probably forgot to do git submodule update --recursive after
checking out the branch.
Am 01.04.21 um 09:31 schrieb Shane at Kilve-Engineering.co.uk:
> Then how come if I delete the repository and then re download the
> problem is still there?
> Regards
> Shane
>> On 1 Apr 2021, at 07:10, Michael Balzer <dexter at expeedo.de> wrote:
>>  By merging my fix… which already has been done.
>> Am 31.03.21 um 19:58 schrieb Shane @ Kilve Engineering:
>>> Hi Michael, this had already made its way into the
>>> https://github.com/MG-EV-Hackers/Open-Vehicle-Monitoring-System-3-MGEV
>>> <https://github.com/MG-EV-Hackers/Open-Vehicle-Monitoring-System-3-MGEV> repository
>>> how’s best to fix this?
>>> Regards
>>> Shane
>>>> On 31 Mar 2021, at 13:04, Michael Balzer <dexter at expeedo.de
>>>> <mailto:dexter at expeedo.de>> wrote:
>>>> Shane,
>>>> found it: you've broken it by your pull request #596, and I've
>>>> broken it by not recognizing this when reviewing your PR.
>>>> You added a revert of the mongoose submodule checkout point to your PR:
>>>> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/596/files#diff-5ab2a552f205c6fe33b157a2dc27590aa7258070eb926a8fc3719657dbcc2fd4
>>>> I've pushed the fix & published a new build to edge.
>>>> Regards,
>>>> Michael
>>>> Am 31.03.21 um 13:21 schrieb Shane at Kilve-Engineering.co.uk:
>>>>> It’s using time from gps as that’s ticked
>>>>> Only started last few days but is ok on an older bin file
>>>>> Regards
>>>>> Shane Hunns
>>>>> Kilve Engineering Ltd.
>>>>> 0792 0729 316
>>>>>> On 31 Mar 2021, at 12:13, Michael Balzer <dexter at expeedo.de> wrote:
>>>>>>  Strange. No issues here, no reports from other users… the cert
>>>>>> hasn't changed in a while and is valid for another month. The CA
>>>>>> cert is valid until september.
>>>>>> Does your module have the right system date?
>>>>>> Regards,
>>>>>> Michael
>>>>>> Am 31.03.21 um 12:54 schrieb Shane @ Kilve Engineering:
>>>>>>> Have you broke something?
>>>>>>> E (2710323) ovms-server-v2: mg_connect(ovms.dexters-web.de:6870
>>>>>>> <http://ovms.dexters-web.de:6870/>) failed: Invalid SSL CA cert
>>>>>>> E (2710323) ovms-server-v2: Status: Error: Connection failed
>>>>>>> I (2770323) ovms-server-v2: Connection is
>>>>>>> ovms.dexters-web.de:6870 <http://ovms.dexters-web.de:6870/>
>>>>>>> maxushunnsnet
>>>>>>> I (2770323) ovms-server-v2: Status: Connecting...
>>>>>>> E (2770333) ovms-server-v2: mg_connect(ovms.dexters-web.de:6870
>>>>>>> E (2770333) ovms-server-v2: Status: Error: Connection failed
>>>>>>> I (2830323) ovms-server-v2: Connection is
>>>>>>> maxushunnsnet
>>>>>>> I (2830323) ovms-server-v2: Status: Connecting...
>>>>>>> E (2830353) ovms-server-v2: mg_connect(ovms.dexters-web.de:6870
>>>>>>> E (2830353) ovms-server-v2: Status: Error: Connection failed
>>>>>>> I (2890323) ovms-server-v2: Connection is
>>>>>>> maxushunnsnet
>>>>>>> I (2890323) ovms-server-v2: Status: Connecting...
>>>>>>> E (2890323) ovms-server-v2: mg_connect(ovms.dexters-web.de:6870
>>>>>>> E (2890323) ovms-server-v2: Status: Error: Connection failed
>>>>>>> I (2950323) ovms-server-v2: Connection is
>>>>>>> maxushunnsnet
>>>>>>> I (2950323) ovms-server-v2: Status: Connecting...
>>>>>>> E (2950323) ovms-server-v2: mg_connect(ovms.dexters-web.de:6870
>>>>>>> E (2950323) ovms-server-v2: Status: Error: Connection failed
>>>>>>> I (3001323) housekeeping: 2021-03-31 10:07:14 BST (RAM:
>>>>>>> 8b=72312-80768 32b=10360)
>>>>>>> I (3010323) ovms-server-v2: Connection is
>>>>>>> maxushunnsnet
>>>>>>> I (3010323) ovms-server-v2: Status: Connecting...
>>>>>>> E (3010323) ovms-server-v2: mg_connect(ovms.dexters-web.de:6870
>>>>>>> E (3010323) ovms-server-v2: Status: Error: Connection failed
>>>>>>> I (3070323) ovms-server-v2: Connection is
>>>>>>> maxushunnsnet
>>>>>>> I (3070323) ovms-server-v2: Status: Connecting...
>>>>>>> E (3070323) ovms-server-v2: mg_connect(ovms.dexters-web.de:6870
>>>>>>> E (3070323) ovms-server-v2: Status: Error: Connection failed
>>>>>>> I (3130323) ovms-server-v2: Connection is
>>>>>>> maxushunnsnet
>>>>>>> I (3130323) ovms-server-v2: Status: Connecting...
>>>>>>> E (3130353) ovms-server-v2: mg_connect(ovms.dexters-web.de:6870
>>>>>>> E (3130353) ovms-server-v2: Status: Error: Connection failed
>>>>>>> I (3190323) ovms-server-v2: Connection is
>>>>>>> maxushunnsnet
>>>>>>> I (3190323) ovms-server-v2: Status: Connecting...
>>>>>>> E (3190323) ovms-server-v2: mg_connect(ovms.dexters-web.de:6870
>>>>>>> E (3190323) ovms-server-v2: Status: Error: Connection failed
>>>>>>> I (3250323) ovms-server-v2: Connection is
>>>>>>> maxushunnsnet
>>>>>>> I (3250323) ovms-server-v2: Status: Connecting...
>>>>>>> E (3250323) ovms-server-v2: mg_connect(ovms.dexters-web.de:6870
>>>>>>> E (3250333) ovms-server-v2: Status: Error: Connection failed
>>>>>>> I (3301323) housekeeping: 2021-03-31 10:12:14 BST (RAM:
>>>>>>> I (3310323) ovms-server-v2: Connection is
>>>>>>> maxushunnsnet
>>>>>>> I (3310323) ovms-server-v2: Status: Connecting...
>>>>>>> E (3310333) ovms-server-v2: mg_connect(ovms.dexters-web.de:6870
>>>>>>> E (3310333) ovms-server-v2: Status: Error: Connection failed
>>>>>>> W (3717913) websocket: WebSocketHandler[0x3f84d2d0]: job queue
>>>>>>> overflow resolved, 1948 drops
>>>>>>> I (3730323) ovms-server-v2: Connection is
>>>>>>> maxushunnsnet
>>>>>>> I (3730323) ovms-server-v2: Status: Connecting...
>>>>>>> E (3730353) ovms-server-v2: mg_connect(ovms.dexters-web.de:6870
>>>>>>> Regards
>>>>>>> Shane Hunns
>>>>>>> 0792 0729 316
>>>>>> OvmsDev mailing list
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210401/a1c29068/attachment-0001.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210401/a1c29068/attachment-0001.sig>
