[Ovmsdev] ESP32 CAN controller hardware bug / interrupt issue
Fri Apr 2 14:51:02 HKT 2021
It's 17 months after my report, and – lo & behold – Espressif just fixed
the issue in their TWAI driver:
https://github.com/espressif/esp-idf/commit/2f5806092135e3d991057bc06225bdcf536e93a5
The commit includes three more workarounds for hardware bugs (see
options added to Kconfig) probably worth checking for our driver:
1. "Add SW workaround for REC change during bus-off" – apparently the
receive error counter can get stuck on a bus-off event preventing
recovery
2. "Add SW workaround for TX interrupt lost errata" – apparently
there's a race condition when reading the transmit interrupt
3. "Add SW workaround for invalid RX frame errata" – this already has
been spotted by Craig, and he's added a counter for this, but it
seems the fix also does a controller reset when this occurs → we
probably should do so as well?
Issue #1 could be the cause for the occasional CAN1 freezes we see, with
the CAN watchdog being our current workaround. #2 could cause a similar
effect, especially on a polling-only bus.
So it could be worth porting those fixes to our driver. Craig, do you
want to take this on?
Am 01.11.19 um 12:35 schrieb Michael Balzer:
> An unusual fast reply from Espressif. They basically declared it to be
> a feature…
> https://github.com/espressif/esp-idf/issues/4276#issuecomment-548753085
> <https://github.com/espressif/esp-idf/issues/4276#issuecomment-548753085>
> Am 01.11.19 um 10:34 schrieb Michael Balzer:
>> I've submitted an issue to Espressif on this:
>> <https://github.com/espressif/esp-idf/issues/4276>
>> It would be nice if I could reproduce the effect using some standard
>> hardware.
>> I've ordered some of those combined ESP32 + OLED units, but don't
>> have any CAN transceivers I could hook up to them.
>> Maybe the info I've provided is sufficient for Espressif to investigate.
>> Am 31.10.19 um 22:24 schrieb Michael Balzer:
>>> Second finding & commit:
>>> TL;DR:
>>> * ESP32 CAN controller is broken, delivers trashed & duplicated RX
>>> frames
>>> * we need to optimize interrupt latency
>>> Users have been reporting occasional false BMS readings on the Twizy
>>> for more than a year.
>>> The error always trashed the reading of voltage #10 and/or
>>> temperature #8, so I initially
>>> thought that must be a variant of the SPIRAM/cache bug.
>>> But the SPIRAM fix didn't help, and the bug still occured with all
>>> BMS data in internal
>>> RAM. The issue correlated with high load situations and the SIMCOM
>>> UART issue. On testing the
>>> latest changes by Marko, my car module began showing that issue
>>> regularly, so I could take a
>>> closer look. It turned out the wrong data came from the CAN bus.
>>> Checking with a CAN logger
>>> didn't show any wrong data on the bus.
>>> So I scanned our CAN driver for potential issues, found & solved
>>> some (even a serious
>>> race condition) but that didn't fix it. I then added debug dumps of
>>> all frames read, dug
>>> into the SJA1000 spec sheet and found this:
>>> The SJA1000 RX FIFO has a capacity of 64 bytes. It's supposed to
>>> work as a ring buffer,
>>> with frames wrapping around as necessary. If no space is left in the
>>> FIFO for a new frame
>>> coming in, that frame should be discarded completely, not counted,
>>> just the overflow
>>> indicator should be set & the according interrupt be generated.
>>> Reality differs. The frame causing the overflow is added to the FIFO
>>> partially. It's also
>>> counted both in the RMC register and indicated by RBS as a valid
>>> frame when retrieving
>>> the FIFO contents. The read buffer delivers the partial frame + some
>>> trashed bytes up
>>> to the nominal frame length.
>>> In the BMS frame sequence it would normally trash bytes 7 & 8 on the
>>> sixth frame of length
>>> 8 in a sequence. A standard frame needs a 3 byte header + the data
>>> bytes in the FIFO, so
>>> 6 frames would add up to 66 bytes => 64 + 2 trash. The first trash
>>> byte normally is "08",
>>> the second "84" or "2a" or sometimes "ab", possibly some internal
>>> SJA1000 data.
>>> Better yet, if you rely on the indicators of the SJA1000 when
>>> reading the FIFO, the
>>> SJA1000 will repeat the first frame within the FIFO after the
>>> invalid frame. Mostly
>>> once or twice, and sometimes 7 times or more:
>>> inv_msg: framecnt=13, invindex=6
>>> inv_msg: 55 01 00 00 07 98 50 54 54 20 00 6e | 4..?........U.....PTT .n
>>> inv_msg: 24 04 00 00 11 40 10 22 37 55 00 37 | 4..?........$.... at ."7U.7
>>> inv_msg: 25 04 00 00 0a 1b 44 ff fe 4e 01 26 | 4..?........%.....D..N.&
>>> inv_msg: 54 05 00 00 37 37 37 37 37 37 37 00 | 4..?........T...7777777.
>>> inv_msg: 56 05 00 00 31 63 14 31 53 14 31 4a | 4..?........V...1c.1S.1J
>>> inv_msg: 57 05 00 00 31 43 14 31 53 15 *08 2a* |
>>> 4..?........W...1C.1S..*
>>> ^^^^^ trashed bytes
>>> … followed by 7 repetitions of the first frame:
>>> If you had occasional strange false readings leading to strange
>>> effects, this
>>> may be the explanation. Note: the SJA1000 FIFO bug may need specific
>>> circumstance
>>> to occur in addition to the overflow, maybe the overflow happening
>>> on a specific
>>> byte position in the FIFO -- I haven't tried to determine that.
>>> I've tried clearing the overflow ASAP, looping on the IR indicator
>>> and looping
>>> on the RMC, the fault is always the same. The workaround I've now
>>> done is adding
>>> up the message lengths read during a FIFO run and discard all frames
>>> exceeding
>>> the 64 byte border. Not pretty, but functional.
>>> That keeps the trashed frames from being forwarded to the OVMS
>>> application level.
>>> As with the SIMCOM UART, these overflows wouldn't happen if the
>>> interrupt handler
>>> would react fast enough. It seems we've got a general interrupt
>>> latency issue.
>>> And just as with the SIMCOM I saw a reduction of overflows when
>>> allocating the
>>> CAN IRQ on core #0, another one with raising the IRQ level to 3, so
>>> that's
>>> also part of my commit.
>>> The esp-idf CAN driver apparently has the same issue even in the
>>> latest release,
>>> I'll contact the author about this or post another issue to Espressif.
>>> So our interrupt allocation is now:
>>> Task Run# Lvl ISR# Usage Source
>>> - 0 1 0 RTC Core
>>> ETS_RTC_CORE_INTR_SOURCE
>>> esp_timer 0 1 0 RTOS esp_timer
>>> ETS_TIMER2_INTR_SOURCE
>>> ipc0 0 1 0 RTOS Scheduler Core0
>>> ETS_FROM_CPU_INTR0_SOURCE
>>> ipc1 1 1 1 RTOS Scheduler Core1
>>> ETS_FROM_CPU_INTR1_SOURCE
>>> main 0 1 0 RTOS Watchdog
>>> ETS_TG0_WDT_LEVEL_INTR_SOURCE
>>> OVMS Events 1 1 1 Peripherals (GPIO ISR)
>>> ETS_GPIO_INTR_SOURCE
>>> OVMS Events 1 1 1 MAX7317 (spi_nodma)
>>> ETS_SPI3_INTR_SOURCE
>>> *esp32can init 0 3 0 ESP32 CAN
>>> ETS_CAN_INTR_SOURCE**
>>> **OVMS SIMCOM 0 2 0 SIMCOM UART
>>> ETS_UART1_INTR_SOURCE*
>>> OVMS Events 1 1 1 USB console (UART)
>>> ETS_UART0_INTR_SOURCE
>>> OVMS Events 1 1 1 SD card
>>> ETS_SDIO_HOST_INTR_SOURCE
>>> I think we need to find the source of the interrupt latency and/or
>>> find some
>>> better scheme to distribute the tasks & interrupts over the cores.
>>> I still don't know why core #1 already got an issue with just our 6
>>> interrupts.
>>> This may be related to the SPIRAM fix adding overhead, but I've seen
>>> the FIFO
>>> overflows before applying the fix, and the CAN issue also has been
>>> present for
>>> over a year.
>>> My working hypothesis is some task/driver disabling interrupts for
>>> too often
>>> / too long, or non-IRAM ISRs getting delayed for too often / too
>>> long. And it
>>> seems this is an issue especially on core #1.
>>> Please verify & comment.
>>> PS: a little side mystery: the netmanager task starts with priority
>>> 5, then
>>> gets raised to 22 (probably a mutex priority inheritance), but never
>>> gets
>>> lowered back to 5 afterwards. A FreeRTOS bug?
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210402/b081aca8/attachment-0001.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210402/b081aca8/attachment-0001.sig>
