[Ovmsdev] ssl cert
Shane@Kilve-Engineering.co.uk
shane at kilve-engineering.co.uk
Thu Apr 1 15:31:37 HKT 2021
Then how come if I delete the repository and then re download the problem is still there?
Regards
Shane
> On 1 Apr 2021, at 07:10, Michael Balzer <dexter at expeedo.de> wrote:
> By merging my fix… which already has been done.
> Am 31.03.21 um 19:58 schrieb Shane @ Kilve Engineering:
>> Hi Michael, this had already made its way into the
>> https://github.com/MG-EV-Hackers/Open-Vehicle-Monitoring-System-3-MGEV repository how’s best to fix this?
>> Regards
>> Shane
>>> On 31 Mar 2021, at 13:04, Michael Balzer <dexter at expeedo.de> wrote:
>>> Shane,
>>> found it: you've broken it by your pull request #596, and I've broken it by not recognizing this when reviewing your PR.
>>> You added a revert of the mongoose submodule checkout point to your PR:
>>> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/596/files#diff-5ab2a552f205c6fe33b157a2dc27590aa7258070eb926a8fc3719657dbcc2fd4
>>> I've pushed the fix & published a new build to edge.
>>> Am 31.03.21 um 13:21 schrieb Shane at Kilve-Engineering.co.uk:
>>>> It’s using time from gps as that’s ticked
>>>> Only started last few days but is ok on an older bin file
>>>> Regards
>>>> Shane Hunns
>>>> Kilve Engineering Ltd.
>>>> 0792 0729 316
>>>>> On 31 Mar 2021, at 12:13, Michael Balzer <dexter at expeedo.de> wrote:
>>>>> Strange. No issues here, no reports from other users… the cert hasn't changed in a while and is valid for another month. The CA cert is valid until september.
>>>>> Does your module have the right system date?
>>>>> Regards,
>>>>> Michael
>>>>> Am 31.03.21 um 12:54 schrieb Shane @ Kilve Engineering:
>>>>>> Have you broke something?
>>>>>> E (2710323) ovms-server-v2: mg_connect(ovms.dexters-web.de:6870) failed: Invalid SSL CA cert
>>>>>> E (2710323) ovms-server-v2: Status: Error: Connection failed
>>>>>> I (2770323) ovms-server-v2: Connection is ovms.dexters-web.de:6870 maxushunnsnet
>>>>>> I (2770323) ovms-server-v2: Status: Connecting...
>>>>>> E (2770333) ovms-server-v2: mg_connect(ovms.dexters-web.de:6870) failed: Invalid SSL CA cert
>>>>>> E (2770333) ovms-server-v2: Status: Error: Connection failed
>>>>>> I (2830323) ovms-server-v2: Connection is ovms.dexters-web.de:6870 maxushunnsnet
>>>>>> I (2830323) ovms-server-v2: Status: Connecting...
>>>>>> E (2830353) ovms-server-v2: mg_connect(ovms.dexters-web.de:6870) failed: Invalid SSL CA cert
>>>>>> E (2830353) ovms-server-v2: Status: Error: Connection failed
>>>>>> I (2890323) ovms-server-v2: Connection is ovms.dexters-web.de:6870 maxushunnsnet
>>>>>> I (2890323) ovms-server-v2: Status: Connecting...
>>>>>> E (2890323) ovms-server-v2: mg_connect(ovms.dexters-web.de:6870) failed: Invalid SSL CA cert
>>>>>> E (2890323) ovms-server-v2: Status: Error: Connection failed
>>>>>> I (2950323) ovms-server-v2: Connection is ovms.dexters-web.de:6870 maxushunnsnet
>>>>>> I (2950323) ovms-server-v2: Status: Connecting...
>>>>>> E (2950323) ovms-server-v2: mg_connect(ovms.dexters-web.de:6870) failed: Invalid SSL CA cert
>>>>>> E (2950323) ovms-server-v2: Status: Error: Connection failed
>>>>>> I (3001323) housekeeping: 2021-03-31 10:07:14 BST (RAM: 8b=72312-80768 32b=10360)
>>>>>> I (3010323) ovms-server-v2: Connection is ovms.dexters-web.de:6870 maxushunnsnet
>>>>>> I (3010323) ovms-server-v2: Status: Connecting...
>>>>>> E (3010323) ovms-server-v2: mg_connect(ovms.dexters-web.de:6870) failed: Invalid SSL CA cert
>>>>>> E (3010323) ovms-server-v2: Status: Error: Connection failed
>>>>>> I (3070323) ovms-server-v2: Connection is ovms.dexters-web.de:6870 maxushunnsnet
>>>>>> I (3070323) ovms-server-v2: Status: Connecting...
>>>>>> E (3070323) ovms-server-v2: mg_connect(ovms.dexters-web.de:6870) failed: Invalid SSL CA cert
>>>>>> E (3070323) ovms-server-v2: Status: Error: Connection failed
>>>>>> I (3130323) ovms-server-v2: Connection is ovms.dexters-web.de:6870 maxushunnsnet
>>>>>> I (3130323) ovms-server-v2: Status: Connecting...
>>>>>> E (3130353) ovms-server-v2: mg_connect(ovms.dexters-web.de:6870) failed: Invalid SSL CA cert
>>>>>> E (3130353) ovms-server-v2: Status: Error: Connection failed
>>>>>> I (3190323) ovms-server-v2: Connection is ovms.dexters-web.de:6870 maxushunnsnet
>>>>>> I (3190323) ovms-server-v2: Status: Connecting...
>>>>>> E (3190323) ovms-server-v2: mg_connect(ovms.dexters-web.de:6870) failed: Invalid SSL CA cert
>>>>>> E (3190323) ovms-server-v2: Status: Error: Connection failed
>>>>>> I (3250323) ovms-server-v2: Connection is ovms.dexters-web.de:6870 maxushunnsnet
>>>>>> I (3250323) ovms-server-v2: Status: Connecting...
>>>>>> E (3250323) ovms-server-v2: mg_connect(ovms.dexters-web.de:6870) failed: Invalid SSL CA cert
>>>>>> E (3250333) ovms-server-v2: Status: Error: Connection failed
>>>>>> I (3301323) housekeeping: 2021-03-31 10:12:14 BST (RAM: 8b=72312-80768 32b=10360)
>>>>>> I (3310323) ovms-server-v2: Connection is ovms.dexters-web.de:6870 maxushunnsnet
>>>>>> I (3310323) ovms-server-v2: Status: Connecting...
>>>>>> E (3310333) ovms-server-v2: mg_connect(ovms.dexters-web.de:6870) failed: Invalid SSL CA cert
>>>>>> E (3310333) ovms-server-v2: Status: Error: Connection failed
>>>>>> W (3717913) websocket: WebSocketHandler[0x3f84d2d0]: job queue overflow resolved, 1948 drops
>>>>>> I (3730323) ovms-server-v2: Connection is ovms.dexters-web.de:6870 maxushunnsnet
>>>>>> I (3730323) ovms-server-v2: Status: Connecting...
>>>>>> E (3730353) ovms-server-v2: mg_connect(ovms.dexters-web.de:6870) failed: Invalid SSL CA cert
>>>>>> Regards
>>>>>> Shane Hunns
>>>>>> 0792 0729 316
>>>>> OvmsDev mailing list
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210401/897e698d/attachment-0001.htm>
Type: application/octet-stream
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210401/897e698d/attachment-0001.obj>
