[Ovmsdev] ssl cert
Thu Apr 1 14:10:02 HKT 2021
By merging my fix… which already has been done.
Am 31.03.21 um 19:58 schrieb Shane @ Kilve Engineering:
> Hi Michael, this had already made its way into the
> https://github.com/MG-EV-Hackers/Open-Vehicle-Monitoring-System-3-MGEV
> <https://github.com/MG-EV-Hackers/Open-Vehicle-Monitoring-System-3-MGEV> repository
> how’s best to fix this?
> Regards
> Shane
>> On 31 Mar 2021, at 13:04, Michael Balzer <dexter at expeedo.de
>> Shane,
>> found it: you've broken it by your pull request #596, and I've broken
>> it by not recognizing this when reviewing your PR.
>> You added a revert of the mongoose submodule checkout point to your PR:
>> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/596/files#diff-5ab2a552f205c6fe33b157a2dc27590aa7258070eb926a8fc3719657dbcc2fd4
>> I've pushed the fix & published a new build to edge.
>> Am 31.03.21 um 13:21 schrieb Shane at Kilve-Engineering.co.uk:
>>> It’s using time from gps as that’s ticked
>>> Only started last few days but is ok on an older bin file
>>> Regards
>>> Shane Hunns
>>> Kilve Engineering Ltd.
>>> 0792 0729 316
>>>> On 31 Mar 2021, at 12:13, Michael Balzer <dexter at expeedo.de> wrote:
>>>> Strange. No issues here, no reports from other users… the cert
>>>> hasn't changed in a while and is valid for another month. The CA
>>>> cert is valid until september.
>>>> Does your module have the right system date?
>>>> Regards,
>>>> Michael
>>>> Am 31.03.21 um 12:54 schrieb Shane @ Kilve Engineering:
>>>>> Have you broke something?
>>>>> E (2710323) ovms-server-v2: mg_connect(ovms.dexters-web.de:6870
>>>>> <http://ovms.dexters-web.de:6870/>) failed: Invalid SSL CA cert
>>>>> E (2710323) ovms-server-v2: Status: Error: Connection failed
>>>>> I (2770323) ovms-server-v2: Connection is ovms.dexters-web.de:6870
>>>>> <http://ovms.dexters-web.de:6870/> maxushunnsnet
>>>>> I (2770323) ovms-server-v2: Status: Connecting...
>>>>> E (2770333) ovms-server-v2: mg_connect(ovms.dexters-web.de:6870
>>>>> E (2770333) ovms-server-v2: Status: Error: Connection failed
>>>>> I (2830323) ovms-server-v2: Connection is ovms.dexters-web.de:6870
>>>>> I (2830323) ovms-server-v2: Status: Connecting...
>>>>> E (2830353) ovms-server-v2: mg_connect(ovms.dexters-web.de:6870
>>>>> E (2830353) ovms-server-v2: Status: Error: Connection failed
>>>>> I (2890323) ovms-server-v2: Connection is ovms.dexters-web.de:6870
>>>>> I (2890323) ovms-server-v2: Status: Connecting...
>>>>> E (2890323) ovms-server-v2: mg_connect(ovms.dexters-web.de:6870
>>>>> E (2890323) ovms-server-v2: Status: Error: Connection failed
>>>>> I (2950323) ovms-server-v2: Connection is ovms.dexters-web.de:6870
>>>>> I (2950323) ovms-server-v2: Status: Connecting...
>>>>> E (2950323) ovms-server-v2: mg_connect(ovms.dexters-web.de:6870
>>>>> E (2950323) ovms-server-v2: Status: Error: Connection failed
>>>>> I (3001323) housekeeping: 2021-03-31 10:07:14 BST (RAM:
>>>>> 8b=72312-80768 32b=10360)
>>>>> I (3010323) ovms-server-v2: Connection is ovms.dexters-web.de:6870
>>>>> I (3010323) ovms-server-v2: Status: Connecting...
>>>>> E (3010323) ovms-server-v2: mg_connect(ovms.dexters-web.de:6870
>>>>> E (3010323) ovms-server-v2: Status: Error: Connection failed
>>>>> I (3070323) ovms-server-v2: Connection is ovms.dexters-web.de:6870
>>>>> I (3070323) ovms-server-v2: Status: Connecting...
>>>>> E (3070323) ovms-server-v2: mg_connect(ovms.dexters-web.de:6870
>>>>> E (3070323) ovms-server-v2: Status: Error: Connection failed
>>>>> I (3130323) ovms-server-v2: Connection is ovms.dexters-web.de:6870
>>>>> I (3130323) ovms-server-v2: Status: Connecting...
>>>>> E (3130353) ovms-server-v2: mg_connect(ovms.dexters-web.de:6870
>>>>> E (3130353) ovms-server-v2: Status: Error: Connection failed
>>>>> I (3190323) ovms-server-v2: Connection is ovms.dexters-web.de:6870
>>>>> I (3190323) ovms-server-v2: Status: Connecting...
>>>>> E (3190323) ovms-server-v2: mg_connect(ovms.dexters-web.de:6870
>>>>> E (3190323) ovms-server-v2: Status: Error: Connection failed
>>>>> I (3250323) ovms-server-v2: Connection is ovms.dexters-web.de:6870
>>>>> I (3250323) ovms-server-v2: Status: Connecting...
>>>>> E (3250323) ovms-server-v2: mg_connect(ovms.dexters-web.de:6870
>>>>> E (3250333) ovms-server-v2: Status: Error: Connection failed
>>>>> I (3301323) housekeeping: 2021-03-31 10:12:14 BST (RAM:
>>>>> I (3310323) ovms-server-v2: Connection is ovms.dexters-web.de:6870
>>>>> I (3310323) ovms-server-v2: Status: Connecting...
>>>>> E (3310333) ovms-server-v2: mg_connect(ovms.dexters-web.de:6870
>>>>> E (3310333) ovms-server-v2: Status: Error: Connection failed
>>>>> W (3717913) websocket: WebSocketHandler[0x3f84d2d0]: job queue
>>>>> overflow resolved, 1948 drops
>>>>> I (3730323) ovms-server-v2: Connection is ovms.dexters-web.de:6870
>>>>> I (3730323) ovms-server-v2: Status: Connecting...
>>>>> E (3730353) ovms-server-v2: mg_connect(ovms.dexters-web.de:6870
>>>>> Regards
>>>>> Shane Hunns
>>>>> 0792 0729 316
>>>> OvmsDev mailing list
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210401/c009fda7/attachment-0001.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210401/c009fda7/attachment-0001.sig>
