[Ovmsdev] Need some help on CAN errors
Chris van der Meijden
chris at arachnon.de
Sat Sep 19 19:13:50 HKT 2020
Perfect! Thanx.
I'm back on track on monday.
Regards
Chris
Am Samstag, den 19.09.2020, 13:12 +0200 schrieb Michael Balzer:
> Chris,
> I've now set up a test environment for CAN2 & 3 and have begun
> investigating the issue.
> I'll come back to you when I've fixed it.
> Am 18.09.20 um 19:51 schrieb Michael
> Balzer:
> > Chris,
> > the fix isn't meant to eliminate bus errors, it just should
> > solve
> > the log errors.
> > I.e. you should now see exactly those frames in the TX log,
> > that
> > you transmit.
> > TX_Fail log entries can result from actual bus errors as well
> > as
> > from TX queue overflows.
> > TX queue overflows are counted separately, see can can3
> > status. If you have TX overflows, you need to raise the
> > queue size.
> > Regards,
> > Michael
> > Am 18.09.20 um 19:38 schrieb Chris
> > van der Meijden:
> > > I did a first test with mixed results.
> > > I don't see the Asynchronous Errors anymore, but I see
> > > TX_FAIL messages and neither unlocking nor climate
> > > control
> > > works with the patch.
> > > I will continue on monday with some deeper checks and I
> > > hope I can produce some
> > > log output then.
> > > Regards
> > > Chris
> > > _______________________________________________
> > > OvmsDev mailing list
> > > OvmsDev at lists.openvehicles.com
> > > http://lists.openvehicles.com/mailman/listinfo/ovmsdev
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200919/5ba1d3c6/attachment-0002.htm>
