[Ovmsdev] Need some help on CAN errors
Sat Sep 19 19:12:14 HKT 2020
Chris,
I've now set up a test environment for CAN2 & 3 and have begun
investigating the issue.
I'll come back to you when I've fixed it.
Am 18.09.20 um 19:51 schrieb Michael Balzer:
> Chris,
> the fix isn't meant to eliminate bus errors, it just should solve the
> log errors.
> I.e. you should now see exactly those frames in the TX log, that you
> transmit.
> TX_Fail log entries can result from actual bus errors as well as from
> TX queue overflows.
> TX queue overflows are counted separately, see can can3 status. If you
> have TX overflows, you need to raise the queue size.
> Am 18.09.20 um 19:38 schrieb Chris van der Meijden:
>> I did a first test with mixed results.
>> I don't see the Asynchronous Errors anymore, but I see TX_FAIL
>> messages and neither unlocking nor climate control works with the patch.
>> I will continue on monday with some deeper checks and I hope I can
>> produce some
>> log output then.
>> Regards
>> Chris
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200919/9e526325/attachment-0002.htm>
