[Ovmsdev] Need some help on CAN errors
Sat Sep 19 01:51:29 HKT 2020
Chris,
the fix isn't meant to eliminate bus errors, it just should solve the
log errors.
I.e. you should now see exactly those frames in the TX log, that you
transmit.
TX_Fail log entries can result from actual bus errors as well as from TX
queue overflows.
TX queue overflows are counted separately, see can can3 status. If you
have TX overflows, you need to raise the queue size.
Am 18.09.20 um 19:38 schrieb Chris van der Meijden:
> I did a first test with mixed results.
> I don't see the Asynchronous Errors anymore, but I see TX_FAIL
> messages and neither unlocking nor climate control works with the patch.
> I will continue on monday with some deeper checks and I hope I can
> produce some
> log output then.
> Regards
> Chris
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200918/909bb446/attachment-0002.htm>
