[Ovmsdev] Need some help on CAN errors
Sun Sep 20 19:57:48 HKT 2020
Chris & everyone,
I've pushed my fix for the out of sequence transmissions and faulty
transmission logs on bulk transmissions. My tests showed the esp32can
driver had the same issue.
The fix uses a mutex to avoid concurrent frame writes from the
application and CAN task context.
In addition I fixed a bug in the mcp2515 driver that caused endless log
spam in case of bus errors -- the same error condition would get logged
over and over again.
Chris, I've also raised the default CAN TX queue size to 30 to allow
your 22 frames to be queued with a standard build as well. But I hope
that's just a first hack and won't be necessary once you figured out how
the protocol works.
Am 19.09.20 um 13:13 schrieb Chris van der Meijden:
> Perfect! Thanx.
> I'm back on track on monday.
> Regards
> Chris
> Am Samstag, den 19.09.2020, 13:12 +0200 schrieb Michael Balzer:
>> Chris,
>> I've now set up a test environment for CAN2 & 3 and have begun
>> investigating the issue.
>> I'll come back to you when I've fixed it.
>> Am 18.09.20 um 19:51 schrieb Michael Balzer:
>>> Chris,
>>> the fix isn't meant to eliminate bus errors, it just should solve
>>> the log errors.
>>> I.e. you should now see exactly those frames in the TX log, that you
>>> transmit.
>>> TX_Fail log entries can result from actual bus errors as well as
>>> from TX queue overflows.
>>> TX queue overflows are counted separately, see can can3 status. If
>>> you have TX overflows, you need to raise the queue size.
>>> Am 18.09.20 um 19:38 schrieb Chris van der Meijden:
>>>> I did a first test with mixed results.
>>>> I don't see the Asynchronous Errors anymore, but I see TX_FAIL
>>>> messages and neither unlocking nor climate control works with the
>>>> patch.
>>>> I will continue on monday with some deeper checks and I hope I can
>>>> produce some
>>>> log output then.
>>>> Regards
>>>> Chris
>>>> OvmsDev mailing list
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200920/26dfd2ec/attachment-0002.htm>
