[Ovmsdev] OBD/UDS error 31
Sun Oct 4 03:37:31 HKT 2020
sharkcow,
I would assume…
> or which attempts to access a dataIdentifier/routineIdentifer that is
> not supported or *not supported in active session*.
…you need to login with a diagnostic session first. Look for
VEHICLE_POLL_TYPE_OBDIISESSION (0x10) requests.
Am 03.10.20 um 20:23 schrieb sharkcow:
> Michael,
> thanks for the explanation.
> Still I'm wondering why the same command works when issued from the
> third-party OBD adapter... are there any setup commands I could look out
> for?
> sharkcow
> Am 03.10.20 um 20:08 schrieb Michael Balzer:
>> sharkcow,
>> 0x22 is VEHICLE_POLL_TYPE_OBDIIEXTENDED and well supported, see vehicle
>> module.
>> See the PDF I just sent you on page 252:
>> Error code 0x31: requestOutOfRange
>>> This response code indicates that the requested action will not be
>>> taken because the
>>> server has detected that the request message contains a parameter
>>> which attempts
>>> to substitute a value beyond its range of authority (e.g. attempting
>>> to substitute a
>>> data byte of 111 when the data is only defined to 100), or which
>>> dataIdentifier/routineIdentifer that is not supported or not supported
>>> in active session.
>>> This response code shall be implemented for all services which allow
>>> the client to
>>> read data, write data or adjust functions by data in the server.
>> Am 03.10.20 um 14:59 schrieb sharkcow:
>>> I'm having trouble getting a multiline OBD message to be read by OVMS.
>>> What exactly does error code 31 mean?
>>> In the OVMS log I see:
>>> D (806212) vehicle: PollerSend(0): send [bus=1, type=22, pid=1821],
>>> expecting 713/77d-77d
>>> D (806222) vehicle: PollerReceive[77D]: process OBD/UDS error 22(1821)
>>> code=31
>>> The only messages with header 713 and 77D in the CAN log are:
>>> 1601729078.788373 1T11 713 03 22 18 21 00 00 00 00
>>> 1601729078.801032 1R11 77D 03 7f 22 31 aa aa aa aa
>>> However, when I log with OVMS what happens when a working third-party
>>> OBD-adapter issues the command, I see:
>>> 1601721047.201952 1R11 713 03 22 18 21 55 55 55 55
>>> 1601721047.210050 1R11 77D 10 2f 62 18 21 01 fe 00
>>> 1601721047.210695 1R11 713 30 ff 01 55 55 55 55 55
>>> 1601721047.214801 1R11 77D 21 00 16 15 00 00 02 20
>>> 1601721047.219865 1R11 77D 22 00 00 00 04 00 00 00
>>> 1601721047.224808 1R11 77D 23 00 00 00 15 91 00 00
>>> 1601721047.230282 1R11 77D 24 01 66 00 00 00 00 00
>>> 1601721047.235039 1R11 77D 25 00 00 00 00 fe c9 c9
>>> 1601721047.240117 1R11 77D 26 c9 c9 ff fe ff ff aa
>>> Does OVMS even support multiline OBD messages? Are there any settings I
>>> should adjust? Any clues? :)
>>> I'm guessing the intermediate "713 30 ff 01" an acknowledge for the
>>> multiline response, does/can OVMS send that?
>>> Thanks for any hints!
>>> sharkcow
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20201003/92746fbe/attachment-0002.htm>
