[Ovmsdev] OBD/UDS error 31
sharkcow sharkcow at gmx.de
Sun Oct 4 02:23:20 HKT 2020
Michael,
thanks for the explanation.
Still I'm wondering why the same command works when issued from the
third-party OBD adapter... are there any setup commands I could look out
for?
sharkcow
Am 03.10.20 um 20:08 schrieb Michael Balzer:
> sharkcow,
> 0x22 is VEHICLE_POLL_TYPE_OBDIIEXTENDED and well supported, see vehicle
> module.
> See the PDF I just sent you on page 252:
> Error code 0x31:  requestOutOfRange
>> This response code indicates that the requested action will not be
>> taken because the
>> server has detected that the request message contains a parameter
>> which attempts
>> to substitute a value beyond its range of authority (e.g. attempting
>> to substitute a
>> data byte of 111 when the data is only defined to 100), or which
>> attempts to access a
>> dataIdentifier/routineIdentifer that is not supported or not supported
>> in active session.
>> This response code shall be implemented for all services which allow
>> the client to
>> read data, write data or adjust functions by data in the server.
> Am 03.10.20 um 14:59 schrieb sharkcow:
>> I'm having trouble getting a multiline OBD message to be read by OVMS.
>> What exactly does error code 31 mean?
>> In the OVMS log I see:
>> D (806212) vehicle: PollerSend(0): send [bus=1, type=22, pid=1821],
>> expecting 713/77d-77d
>> D (806222) vehicle: PollerReceive[77D]: process OBD/UDS error 22(1821)
>> code=31
>> The only messages with header 713 and 77D in the CAN log are:
>> 1601729078.788373 1T11 713 03 22 18 21 00 00 00 00
>> 1601729078.801032 1R11 77D 03 7f 22 31 aa aa aa aa
>> However, when I log with OVMS what happens when a working third-party
>> OBD-adapter issues the command, I see:
>> 1601721047.201952 1R11 713 03 22 18 21 55 55 55 55
>> 1601721047.210050 1R11 77D 10 2f 62 18 21 01 fe 00
>> 1601721047.210695 1R11 713 30 ff 01 55 55 55 55 55
>> 1601721047.214801 1R11 77D 21 00 16 15 00 00 02 20
>> 1601721047.219865 1R11 77D 22 00 00 00 04 00 00 00
>> 1601721047.224808 1R11 77D 23 00 00 00 15 91 00 00
>> 1601721047.230282 1R11 77D 24 01 66 00 00 00 00 00
>> 1601721047.235039 1R11 77D 25 00 00 00 00 fe c9 c9
>> 1601721047.240117 1R11 77D 26 c9 c9 ff fe ff ff aa
>> Does OVMS even support multiline OBD messages? Are there any settings I
>> should adjust? Any clues? :)
>> I'm guessing the intermediate "713 30 ff 01" an acknowledge for the
>> multiline response, does/can OVMS send that?
>> Thanks for any hints!
>> sharkcow
