[Ovmsdev] App for Garmin Watches
Mon Jul 27 10:55:28 HKT 2020
> What do you mean by “you can’t really use that today”? Does it mean I must ask the user for a password and not the token?
Yes. For the moment the user+password is really the only way to access the server. Longer-term we will switch to token.
> On 16 Jul 2020, at 9:17 PM, Sébastien Darveau <sebastien.darveau at synnoetic.com> wrote:
> Ok. I will change the name. The reason for the proxy (AWS Lambda) is that the watch is very picky and I didn’t want to bother you with that. At first, the certificate was apparently the problem but then you fixed it and I was still receiving error codes. Another advantage is that I will be able to strip the content to optimize loading time on the watch.
> Thanks,
> Sebastien
>> On Jul 16, 2020, at 1:17 AM, Mark Webb-Johnson <mark at webb-johnson.net <mailto:mark at webb-johnson.net>> wrote:
>> Sebastien,
>> Sounds exciting. I have some comments/questions:
>> You are free to publish this wherever you desire.
>> Similarly, the logo and images are ok for you to use.
>> We try to use ‘Open Vehicles’ as the name. It is short, but explains the project goals in a better way than the OVMS abbreviation.
>> Do you handle the selection of server (api / Dexter / whatever) or fixed to just api.openvehicles.com <http://api.openvehicles.com/>?
>> Why is your AWS Lambda required? If the HTTP API cannot be used directly, is there a workaround we can do (such as extending the server code) to avoid the requirement for yet another server? I ask because this has security and trust implications for the end-user.
>> A note that medium to long term, it will be better to use api token based authentication - but server side support for that is still in progress so you can’t really use that today.
>>> On 16 Jul 2020, at 3:35 AM, Sébastien Darveau <sebastien.darveau at synnoetic.com <mailto:sebastien.darveau at synnoetic.com>> wrote:
>>> Hi Mark,
>>> I’m working on a widget to see my SOC on my Garmin watch and I’d like to request permission to go further and publish on the Garmin store (https://apps.garmin.com/en-US/ <https://apps.garmin.com/en-US/>) with “OVMS" as name. Once in the store, user will be able to enter vehicle_id, username and password/token to access own car information. Application uses a proxy on AWS Lambda to access the REST Api.
>>> I have taken the resources from the iOS app and reduced the size a bit. Please note that I also use the OVMS logo on the loading screen.
>>> Here is the code: https://github.com/sdarveau/Open-Vehicle-Garmin <https://github.com/sdarveau/Open-Vehicle-Garmin>. Feel free to move it under the openvehicles workspace.
>>> I’m planning to improve it but I'll keep it simple.
>>> Thanks,
>>> Sebastien
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200727/a8218d44/attachment.htm>
