[Ovmsdev] Apple push notifications no longer working
Tue Dec 15 04:20:27 HKT 2020
The certificates are those you sent me. Just checked, they're both valid.
I've added your suggestion and also added the "connected" log message
from PushAPNS.pm, no luck.
2020-12-14 13:52:00.840238 +0100 info  main: - - XXXXXXXX msg queued
apns notification for sandbox:XXXXXXXXXXXXXX
2020-12-14 13:52:01.579649 +0100 info  main: - - - msg apns processing
queue for gateway.sandbox.push.apple.com
2020-12-14 13:52:01.740147 +0100 info  main: - - - msg apns connected to
gateway.sandbox.push.apple.com, now establishing SSL security
I tried reducing the APNS channels to "production", still no luck.
I can see the socket getting created when following socket events:
[root at ns34 ~]# ss -E | grep "17\.188"
tcp    UNCONN  0        0        146.0.237.226:59102 17.188.136.189:2195
So the TLS init somehow fails in a way AnyEvent::Handle doesn't
recognize as a failure / error.
I've had a look at the AnyEvent::Handle documentation but cannot see
anything we're doing wrong or missed regarding error handling.
Maybe Apple is blocking me, dropping all packets? But wouldn't that
trigger a timeout or TLS init error?
Very strange. Any other ideas?
Am 14.12.20 um 09:19 schrieb Mark Webb-Johnson:
> Do you have conf/ovms_apns_sandbox.pem file in place? Valid and not
> expired?
> I had a quick review, and it seems the main flow handles errors.
> Perhaps some other callback on the AnyEvent::Handle for an error
> condition is being missed? Or perhaps the AnyEvent::Handle could not
> be created at all. Can you try to add:
>     If (!defined $apns_handle)
>       AE::log error => "- - - msg apns handle could not be created”;
>       $apns_running = 0;
> After the block of ‘$apns_handle = new AnyEvent::Handle(…’?
>> On 14 Dec 2020, at 3:21 PM, Michael Balzer <dexter at expeedo.de
>> Signed PGP part
>> That's the strange part: I don't get any error, and I don't get a
>> timeout either. That's what I meant by "fails in a way we don't handle".
>> This is the only log entry on "apns processing", I get this once
>> after restarting the server as soon as the first APN is due for delivery:
>> 2020-12-10 16:55:30.351530 +0100 info  main: - - - msg apns
>> processing queue for gateway.sandbox.push.apple.com
>> <http://gateway.sandbox.push.apple.com>
>> (still running server v2 due to lack of time)
>> After that, no more apns processing – I guess because $apns_running
>> never gets reset.
>> Any idea?
>> Am 14.12.20 um 07:17 schrieb Mark Webb-Johnson:
>>> Push notifications are still working ok for me. What is the error
>>> you get back from the gateway?
>>> We are using this protocol (see apns_send function):
>>>     https://developer.apple.com/library/archive/documentation/NetworkingInternet/Conceptual/RemoteNotificationsPG/BinaryProviderAPI.html
>>>     <https://developer.apple.com/library/archive/documentation/NetworkingInternet/Conceptual/RemoteNotificationsPG/BinaryProviderAPI.html>
>>> We need to convert to this one:
>>>     https://developer.apple.com/documentation/usernotifications/setting_up_a_remote_notification_server/sending_notification_requests_to_apns/
>>>     <https://developer.apple.com/documentation/usernotifications/setting_up_a_remote_notification_server/sending_notification_requests_to_apns/>
>>> But have until the end of March 2021 to do it. The switch is not
>>> complex, and is probably slightly easier for us. It becomes just a
>>> simple http request, with pretty much the same payload we currently
>>> use (in json format).
>>>> On 11 Dec 2020, at 12:27 AM, Michael Balzer <dexter at expeedo.de
>>>> Signed PGP part
>>>> Mark,
>>>> a user informed me he no longer gets any push notifications to iOS.
>>>> Looking into the logs, it seems the initial connect to the gateway
>>>> fails in a way the perl code does not handle.
>>>> I've found this in the Apple forums:
>>>> https://developer.apple.com/forums/thread/667248
>>>> <https://developer.apple.com/forums/thread/667248>
>>>> It seems the protocol we use has been deprecated, but it should
>>>> continue to work until March. Do you see a similar effect on your
>>>> server?
>>>> Regards,
>>>> Michael
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20201214/86c288af/attachment.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20201214/86c288af/attachment.sig>
