[Ovmsdev] Apple push notifications no longer working
Mon Dec 14 16:19:38 HKT 2020
Do you have conf/ovms_apns_sandbox.pem file in place? Valid and not expired?
I had a quick review, and it seems the main flow handles errors. Perhaps some other callback on the AnyEvent::Handle for an error condition is being missed? Or perhaps the AnyEvent::Handle could not be created at all. Can you try to add:
If (!defined $apns_handle)
AE::log error => "- - - msg apns handle could not be created”;
$apns_running = 0;
After the block of ‘$apns_handle = new AnyEvent::Handle(…’?
> On 14 Dec 2020, at 3:21 PM, Michael Balzer <dexter at expeedo.de> wrote:
> Signed PGP part
> That's the strange part: I don't get any error, and I don't get a timeout either. That's what I meant by "fails in a way we don't handle".
> This is the only log entry on "apns processing", I get this once after restarting the server as soon as the first APN is due for delivery:
> 2020-12-10 16:55:30.351530 +0100 info main: - - - msg apns processing queue for gateway.sandbox.push.apple.com
> (still running server v2 due to lack of time)
> After that, no more apns processing – I guess because $apns_running never gets reset.
> Any idea?
> Am 14.12.20 um 07:17 schrieb Mark Webb-Johnson:
>> Push notifications are still working ok for me. What is the error you get back from the gateway?
>> We are using this protocol (see apns_send function):
>> https://developer.apple.com/library/archive/documentation/NetworkingInternet/Conceptual/RemoteNotificationsPG/BinaryProviderAPI.html <https://developer.apple.com/library/archive/documentation/NetworkingInternet/Conceptual/RemoteNotificationsPG/BinaryProviderAPI.html>
>> We need to convert to this one:
>> https://developer.apple.com/documentation/usernotifications/setting_up_a_remote_notification_server/sending_notification_requests_to_apns/ <https://developer.apple.com/documentation/usernotifications/setting_up_a_remote_notification_server/sending_notification_requests_to_apns/>
>> But have until the end of March 2021 to do it. The switch is not complex, and is probably slightly easier for us. It becomes just a simple http request, with pretty much the same payload we currently use (in json format).
>>> On 11 Dec 2020, at 12:27 AM, Michael Balzer <dexter at expeedo.de <mailto:dexter at expeedo.de>> wrote:
>>> Signed PGP part
>>> Mark,
>>> a user informed me he no longer gets any push notifications to iOS.
>>> Looking into the logs, it seems the initial connect to the gateway fails in a way the perl code does not handle.
>>> I've found this in the Apple forums: https://developer.apple.com/forums/thread/667248 <https://developer.apple.com/forums/thread/667248>
>>> It seems the protocol we use has been deprecated, but it should continue to work until March. Do you see a similar effect on your server?
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20201214/2812417b/attachment.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20201214/2812417b/attachment.sig>
