[Ovmsdev] Changing Existing Functionalities
Derek Caudwell d.caudwell at gmail.com
Mon Dec 14 13:22:58 HKT 2020
I envisage following a robust testing process outside of the main repo
being a bit more difficult with the Leaf because of the quite substantial
changes in the can bus framework/messages over the years. A change that
works for more recent years but not for prior years is not always easy to
spot, also improvements/additions of metrics may only work on a particular
year unless another dev with a prior year implements and tests them.
Without a group of Leaf devs or testers across the various years that can
be called upon to test prior to putting through a PR to main I expect
future changes will stay in Leaf devs repos untested for other MYs, as
there is no particular reason for others to jump in and test the code to
confirm compatibility.
PR487 will be a good test case to see if the approach proposed can work in
practice.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20201214/0f1eb5d1/attachment.htm>
