[Ovmsdev] Changing Existing Functionalities
    Sun Dec 13 17:20:30 HKT 2020
Derek,
developers typically use their own builds. "edge" is available for
users, and many choose to use it, because new features take long to get
into "eap" & "main".
On my server, user subscriptions are:
  * 72% main
  * 18% edge
  * 10% eap
Of course, "egde" may have bugs, and users know that, but we still
should try hard to only release tested / discussed changes.
You can notify other users on Github by using the "@username" syntax in
posts.
Am 13.12.20 um 00:29 schrieb Derek Caudwell:
> Hi Michael,
> Thanks for clarifying, until then I had been using "edge" on the basis
> that is where other devs would pick up on any issues with other
> models, so that issues got resolved before "eap" where they go out to
> a wider test community.
> Jaunius (@mjkapkan), and other Leaf devs I suggest circulating the
> repo that can be pulled from for testing on this mailing list before
> it goes to the master PR, or is there a way to notify others through
> github?
> Kind regards
> Derek (@drc38)
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20201213/b32cee52/attachment.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20201213/b32cee52/attachment.sig>
