[Ovmsdev] Do I have to flash "entire chip" with esptool if I already have the code on my OVMS box?
Steve Davies
steve at telviva.co.za
Sat Dec 5 21:07:54 HKT 2020
Hi Michael,
Thanks for the reply. I was able to flash my build OTA using the web
server on my laptop and it's running with no trouble.
So far I have added a "stub" for the i3 as per the docs. It is selectable
on the OVMS but of course doesn't produce any data.
On the i3 you have to send in obd2 requests in order to get data - I think
other cars just chatter away unprompted.
Is there another vehicle type that works similarly so I can look at the
code to see how it should be done?
I'm hoping that I can poll the rapidly changing stuff frequently and then
the more static pids maybe once a minute or something.
Steve
On Sat, 5 Dec 2020 at 13:52, Michael Balzer <dexter at expeedo.de> wrote:
> Steve,
> I know of no case of bricking by flashing the firmware.
> Using the developing environment, a simple "make app-flash" will do the
> esptool call for you.
> Of course you can also flash OTA. I usually flash my desk/development
> module by USB and the one in my car via Wifi from my local server. It's up
> to you. Flashing OTA can only update the firmware, but that's normally
> sufficient.
> The "-dirty" tag is appended when building from a "dirty" working tree,
> i.e. one with uncommitted changes.
> Am 05.12.20 um 11:40 schrieb Steve Davies:
> Hi Mark et-al,
> I've installed the esp32 and the esp-idf environments on my Mac and
> successfully build the OVMS firmware.
> In the developer guide it then covers how to flash the box with esptool.
> But: do I need to do that? - my OVMS box is up and running already -
> I'm guessing I can use OTA update to update with
> steve at maximus OVMS.V3 % ls -l build/ovms3.bin
> -rw-r--r-- 1 steve staff 2986336 Dec 5 12:24 build/ovms3.bin
> Since the "flash from web" and and "flash from file" are looking for an
> ovms.bin.
> Nervous to brick my box since it was expensive to get it to Cape Town.
> By the way, my build prints 'App "ovms3" version:
> 3.2.015-162-g10232c58-dirty'
> I recognise the git commit hash, but what is the "-dirty"?
> (I build a "bmwi3" branch of a fork of the original project - maybe that
> answers my own question?)
> My OVMS box currently says it's running "3.2.015/ota_0/main (build idf
> v3.3.2-881-g22d636b7b Sep 2 2020 08:32:35)"
> Thanks,
> Steve
> OvmsDev mailing listOvmsDev at lists.openvehicles.comhttp://lists.openvehicles.com/mailman/listinfo/ovmsdev
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20201205/c426ffab/attachment-0001.htm>
