[Ovmsdev] Do I have to flash "entire chip" with esptool if I already have the code on my OVMS box?
Sat Dec 5 19:53:31 HKT 2020
Links:
- https://docs.openvehicles.com/en/latest/userguide/ota.html
https://docs.openvehicles.com/en/latest/userguide/factory.html#flash-factory-firmware-via-usb
Am 05.12.20 um 12:51 schrieb Michael Balzer:
> Steve,
> I know of no case of bricking by flashing the firmware.
> Using the developing environment, a simple "make app-flash" will do
> the esptool call for you.
> Of course you can also flash OTA. I usually flash my desk/development
> module by USB and the one in my car via Wifi from my local server.
> It's up to you. Flashing OTA can only update the firmware, but that's
> normally sufficient.
> The "-dirty" tag is appended when building from a "dirty" working
> tree, i.e. one with uncommitted changes.
> Am 05.12.20 um 11:40 schrieb Steve Davies:
>> Hi Mark et-al,
>> I've installed the esp32 and the esp-idf environments on my Mac and
>> successfully build the OVMS firmware.
>> In the developer guide it then covers how to flash the box with esptool.
>> But: do I need to do that? - my OVMS box is up and running already -
>> I'm guessing I can use OTA update to update with
>> steve at maximus OVMS.V3 % ls -l build/ovms3.bin
>> -rw-r--r-- 1 steve staff 2986336 Dec 5 12:24 build/ovms3.bin
>> Since the "flash from web" and and "flash from file" are looking for
>> an ovms.bin.
>> Nervous to brick my box since it was expensive to get it to Cape Town.
>> By the way, my build prints 'App "ovms3" version:
>> 3.2.015-162-g10232c58-dirty'
>> I recognise the git commit hash, but what is the "-dirty"?
>> (I build a "bmwi3" branch of a fork of the original project - maybe
>> that answers my own question?)
>> My OVMS box currently says it's running "3.2.015/ota_0/main (build
>> idf v3.3.2-881-g22d636b7b Sep 2 2020 08:32:35)"
>> Thanks,
>> Steve
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20201205/7d5f8c6a/attachment-0001.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20201205/7d5f8c6a/attachment-0001.sig>
