[Ovmsdev] Issues since latest update (3.2.0.14)
Sébastien Darveau sebastien.darveau at synnoetic.com
Mon Aug 31 20:48:24 HKT 2020
Hi Mark,
I did change the DNS but it didn’t fix the problem so I reverted to previous version. It looks like it is Leaf 2015 specific as reported here by someone else:
https://www.openvehicles.com/node/2587
I suspect the new wifi feature because it seems to happen when leaving the wifi range.
Thanks,
Sebastien
On Aug 19, 2020, at 10:50 AM, Mark Webb-Johnson <mark at webb-johnson.net <mailto:mark at webb-johnson.net> > wrote:
Please try with 8.8.8.8, to rule out a dns issue.
The reason I suggest this is because I have seen that ‘parse error’ before resulting from failed dns lookups.
Regards, ?Mark
On 19 Aug 2020, at 9:08 PM, Sébastien Darveau <sebastien.darveau at synnoetic.com <mailto:sebastien.darveau at synnoetic.com> > wrote:
Strangely, it is connected on my home wifi. DNS are 212.9.0.135 and 212.9.0.136 and I can resolve openvehicles.com <http://openvehicles.com/>  correctly with nslookup on my laptop. Since everything works perfectly after a reboot, it is not a dns issue but a degradation while the box is running. It seems to worsen when going out of wifi range and back but I’m still not sure about this.
A new error appeared this morning but probably unrelated:
E (140391333) can: can1: intr=14187292 rxpkt=14151479 txpkt=3057 errflags=0x8040d9 rxerr=0 txerr=131 rxovr=23 txovr=0 txdelay=0 wdgreset=0 errreset=0
Thanks,
Sebastien
On Aug 19, 2020, at 2:25 AM, Mark Webb-Johnson <mark at webb-johnson.net <mailto:mark at webb-johnson.net> > wrote:
What are your DNS servers set to?
Can you try with 8.8.8.8, if you aren’t already, and don’t use ISP/cellular DNS servers.
On 19 Aug 2020, at 2:02 AM, Sébastien Darveau <sebastien.darveau at synnoetic.com <mailto:sebastien.darveau at synnoetic.com> > wrote:
Hello,
Anyone else is having connection issues since latest update? I’m constantly loosing contact with the device and haven’t been able to open a console with USB but this time, I can still access it with the Web interface and noticed it can’t connect to server.
E (72178423) ovms-server-v2: mg_connect(api.openvehicles.com:6867 <http://api.openvehicles.com:6867/> ) failed: cannot parse address
E (72178423) ovms-server-v2: Status: Error: Connection failed
W (72180093) simcom: UART hw fifo overflow
W (72192873) gsm-mux: Frame overflow (2048 bytes)
E (72238423) ovms-server-v2: mg_connect(api.openvehicles.com:6867 <http://api.openvehicles.com:6867/> ) failed: cannot parse address
E (72238423) ovms-server-v2: Status: Error: Connection failed
E (72298463) ovms-server-v2: mg_connect(api.openvehicles.com:6870 <http://api.openvehicles.com:6870/> ) failed: cannot parse address
E (72298463) ovms-server-v2: Status: Error: Connection failed
Address looks good though.
Sebastien Darveau
OvmsDev mailing list
OvmsDev at lists.openvehicles.com <mailto:OvmsDev at lists.openvehicles.com>
http://lists.openvehicles.com/mailman/listinfo/ovmsdev <http://lists.openvehicles.com/mailman/listinfo/ovmsdev>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200831/95398e3c/attachment.htm>
