[Ovmsdev] Issues since latest update (3.2.0.14)
Wed Aug 19 22:50:44 HKT 2020
Please try with 8.8.8.8, to rule out a dns issue.
The reason I suggest this is because I have seen that ‘parse error’ before resulting from failed dns lookups.
Regards, ?Mark
> On 19 Aug 2020, at 9:08 PM, Sébastien Darveau <sebastien.darveau at synnoetic.com> wrote:
> Strangely, it is connected on my home wifi. DNS are 212.9.0.135 and 212.9.0.136 and I can resolve openvehicles.com correctly with nslookup on my laptop. Since everything works perfectly after a reboot, it is not a dns issue but a degradation while the box is running. It seems to worsen when going out of wifi range and back but I’m still not sure about this.
> A new error appeared this morning but probably unrelated:
> E (140391333) can: can1: intr=14187292 rxpkt=14151479 txpkt=3057 errflags=0x8040d9 rxerr=0 txerr=131 rxovr=23 txovr=0 txdelay=0 wdgreset=0 errreset=0
> Thanks,
> Sebastien
>> On Aug 19, 2020, at 2:25 AM, Mark Webb-Johnson <mark at webb-johnson.net> wrote:
>> What are your DNS servers set to?
>> Can you try with 8.8.8.8, if you aren’t already, and don’t use ISP/cellular DNS servers.
>>> On 19 Aug 2020, at 2:02 AM, Sébastien Darveau <sebastien.darveau at synnoetic.com> wrote:
>>> Hello,
>>> Anyone else is having connection issues since latest update? I’m constantly loosing contact with the device and haven’t been able to open a console with USB but this time, I can still access it with the Web interface and noticed it can’t connect to server.
>>> E (72178423) ovms-server-v2: mg_connect(api.openvehicles.com:6867) failed: cannot parse address
>>> E (72178423) ovms-server-v2: Status: Error: Connection failed
>>> W (72180093) simcom: UART hw fifo overflow
>>> W (72192873) gsm-mux: Frame overflow (2048 bytes)
>>> E (72238423) ovms-server-v2: mg_connect(api.openvehicles.com:6867) failed: cannot parse address
>>> E (72238423) ovms-server-v2: Status: Error: Connection failed
>>> E (72298463) ovms-server-v2: mg_connect(api.openvehicles.com:6870) failed: cannot parse address
>>> E (72298463) ovms-server-v2: Status: Error: Connection failed
>>> Address looks good though.
>>> Sebastien Darveau
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200819/88cb6384/attachment.htm>
