[Ovmsdev] New pull requests pending
Mon Aug 17 14:36:20 HKT 2020
Also, on the general handling for pull requests:
It's generally advised to create separate branches for all your pull
requests, each concentrating on just a single feature / development topic.
You can have local development branches as many as you need. Publish
changes ready to be merged into the dedicated pull request branch (i.e.
merge them locally into that branch), then create a pull request on that
branch.
Pull requests track the branch they are created on, so any new commit
added during the discussion will automatically update the pull request.
Once a pull reqest has been merged into the master, you can simply
delete the branch.
Am 17.08.20 um 07:38 schrieb Mark Webb-Johnson:
> Yes, ^this.
> The main repository master should be relatively stable. If we need
> something potentially breaking, or a major restructuring of how things
> are done, then we should do that in a main repository branch. That is
> the reason for the upcoming 3.3 branch (as it restructures the modem
> driver, which could be potentially very breaking - more on this later,
> when I am ready to release).
> Preparing stuff for inclusion in the main repository should in general
> be done in local clone copies, then pull-requests made when ready.
> Regards, Mark
>> On 17 Aug 2020, at 1:08 PM, Soko <ovms at soko.cc <mailto:ovms at soko.cc>>
>> wrote:
>> PS: On a second thought I kinda cannot see the advantage of a PR
>> request into a Dev branch in comparison into the master branch.
>> If the PR is changed and improved until it is approved by you guys it
>> should be OK to go into the master.
>> On 17 August 2020 07:00:37 CEST, Soko <ovms at soko.cc
>> <mailto:ovms at soko.cc>> wrote:
>>     Hi Derek.
>>     I would prefer the first option as discussing source is way
>>     easier on a PR in github as here in the mailing list.
>>     Soko
>>     On 17 August 2020 06:53:40 CEST, Derek Caudwell
>>     <d.caudwell at gmail.com <mailto:d.caudwell at gmail.com>> wrote:
>>         Hi Mark,
>>         Would it possible to have a 'Dev' branch in the main
>>         repository for those of us needing assistance to get a
>>         feature to the point it can be merged into the 'Master'?
>>         If that's not preferred and we use a branch on our own github
>>         clone, is it as simple as providing the link to the branch on
>>         this email list to invite others to collaborate/review?
>>         With the latter approach we may miss out on input from others
>>         not actively monitoring this forum I guess.
>>         Regards Derek
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200817/2dbafae3/attachment.htm>
