[Ovmsdev] New pull requests pending
Chris van der Meijden
chris at arachnon.de
Fri Aug 14 16:56:09 HKT 2020
I agree on not further discussing this. I made my point.
Chris
Am Freitag, den 14.08.2020, 10:02 +0200 schrieb Soko:
> I'm not quite sure if we should discuss this here or in the pull
> request itself. Maybe Mark or Michael should say whats best.
> Anyhow... Let me put you to ease with my answers below...
> On 14.08.2020 09:18, Chris van der
> Meijden wrote:
> > Hey Soko,
> > sorry I don't agree on this pull request.
> Just to make things clear with the other guys: You are talking
> about one of the pull requests, the one with the source split.
> > We have already discussed this.
> > Lets put this straight. My code for the T26A part is not
> > ready yet. Climate control is still very buggy and it would
> > confuse the user to have such a buggy feature within a
> > possible
> > OVMS release. It will take me probably a week or two, maybe
> > longer, to get the climate control fixed. Then we can do a
> > pull
> > request to the master.
> The T26A code in my pull request is not the one from your
> fork. It's the one that is officially in the master branch of
> openvehicles. So nothing changes for the user and not one
> source
> line is different then before.
> > An other point we also talked about, is that you have not
> > documented your OBD part at all. This is also not
> > acceptable.
> > You can't put features with in the official OVMS repository
> > that
> > are not documented at all. How does the user use your VW e-
> > Up
> > OBD part? What hardware is needed? Where does the user see
> > the
> > results in the webfrontend? Does the app work with your
> > code?
> The user is not able to use any of the OBD code as pointed out
> in the pull request description. This is more an esthetic
> question as the code is not active. If the others feel the
> same
> I can remove my obd_*.* files from the pull request. The
> outcome
> is the same...
> > You can't put unready code in the master.
> > That is the reason why we use forks. We merge a fork when we
> > have kind of stable code with features that are well
> > documented.
> > This is not the case at the moment with the splitted VW e-Up
> > code.
> To sum up: Nothing at all changes for the user with me my pull
> request. Well... besides the name of the VW e-Up vehicle. But
> is
> taken care of in the upgrade method.
> I even prepared everything so you have it as easy as possible
> when this pull request is put into the master: When you pull
> it
> your fork you only have to backup your three t26_*.* files
> from
> your fork. Then just take 1:1 the openvehicles-master and put
> your backup back.
> At least that's how I would do it as I'm not familiar how
> this
> is done in git directly ;)
> > Regards
> > Chris
> > Am Freitag, den 14.08.2020, 07:06 +0200 schrieb Soko:
> > > Hey guys,
> > > Just want to let you know on this way as well about the two pull
> > > requests I have opened yesterday.
> > > Let me know your thoughts. Would be cool if they will be merged
> > > very
> > > soon so I can continue my work on the VW e-Up.
> > > regards,
> > > Soko
> > > _______________________________________________
> > > OvmsDev mailing list
> > > OvmsDev at lists.openvehicles.com
> > > http://lists.openvehicles.com/mailman/listinfo/ovmsdev
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200814/481d471f/attachment.htm>
