[Ovmsdev] lost important event => aborting
Wed Aug 26 12:17:13 HKT 2020
A customer is reporting:
Last crash: abort() was called on core 1 Backtrace: 0x4008e627 0x4008e8c1 0x400f2be4 0x400f3145 0x4014a7d1 0x401538b0 0x401082be 0x401092ed 0x401082be 0x40108430 0x4010a3bb 0x4010647a 0x400fb63f 0x400fb6ed Event: ticker.1 at EventScript 0 secs Version: 3.2.014/ota_0/main (build idf v3.3.2-881-g22d636b Aug 4 2020 16:26:20)
He is running a Nissan Leaf, with 3.2.014 firmware. Both v2 and v3 servers enabled, as well as Abrp and pushover.
Trace is:
Using elf file: 3.2.014.ovms3.elf
0x4008e627 is in invoke_abort (/home/openvehicles/build/esp-idf/components/esp32/panic.c:156).
151 #endif
152 while (1) {
153 if (esp_cpu_in_ocd_debug_mode()) {
154 __asm__ ("break 0,0");
155 }
156 *((int *) 0) = 0;
157 }
158 }
159
160 void abort()
0x4008e8c1 is in abort (/home/openvehicles/build/esp-idf/components/esp32/panic.c:171).
166 * don't overwrite that.
167 */
168 if (esp_reset_reason_get_hint() == ESP_RST_UNKNOWN) {
169 esp_reset_reason_set_hint(ESP_RST_PANIC);
170 }
171 invoke_abort();
172 }
173
174
175 static const char *edesc[] = {
0x400f2be4 is in CheckQueueOverflow(char const*, char*) (/home/openvehicles/build/Open-Vehicle-Monitoring-System-3.1/vehicle/OVMS.V3/main/ovms_events.cpp:339).
334 // We've dropped a potentially important event, system is instable now.
335 // As the event queue is full, a normal reboot is no option, so…
336 ESP_LOGE(TAG, "%s: lost important event => aborting", from);
337 MyCommandApp.CloseLogfile();
338 vTaskDelay(pdMS_TO_TICKS(100));
339 abort();
340 }
341 }
342
343 static void SignalScheduledEvent(TimerHandle_t timer)
0x400f3145 is in OvmsEvents::SignalEvent(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, void*, void (*)(char const*, void*), unsigned int) (/home/openvehicles/build/Open-Vehicle-Monitoring-System-3.1/vehicle/OVMS.V3/main/ovms_events.cpp:417).
412
413 if (delay_ms == 0)
414 {
415 if (xQueueSend(m_taskqueue, &msg, 0) != pdTRUE)
416 {
417 CheckQueueOverflow("SignalEvent", msg.body.signal.event);
418 FreeQueueSignalEvent(&msg);
419 }
420 }
421 else
0x4014a7d1 is in OvmsWebServer::DestroyWebSocketHandler(WebSocketHandler*) (/home/openvehicles/build/Open-Vehicle-Monitoring-System-3.1/vehicle/OVMS.V3/components/ovms_webserver/src/ovms_websockethandler.cpp:502).
497
498 // clear unqueued notifications if any:
499 MyNotify.ClearReader(m_client_slots[i].reader);
500
501 ESP_LOGD(TAG, "WebSocket[%p] handler %p closed; %d clients active", nc, handler, m_client_cnt);
502 MyEvents.SignalEvent("server.web.socket.closed", (void*)m_client_cnt);
503
504 break;
505 }
506 }
0x401538b0 is in OvmsWebServer::EventHandler(mg_connection*, int, void*) (/home/openvehicles/build/Open-Vehicle-Monitoring-System-3.1/vehicle/OVMS.V3/components/ovms_webserver/src/ovms_webserver.cpp:534).
529
530 case MG_EV_CLOSE: // connection has been closed
531 {
532 if (handler) {
533 if (nc->flags & MG_F_IS_WEBSOCKET)
534 MyWebServer.DestroyWebSocketHandler((WebSocketHandler*)handler);
535 else
536 delete handler;
537 }
538 }
0x401082be is in mg_call (/home/openvehicles/build/Open-Vehicle-Monitoring-System-3.1/vehicle/OVMS.V3/components/mongoose/mongoose/mongoose.c:2368).
2363 }
2364 #endif
2365 if (ev_handler != NULL) {
2366 unsigned long flags_before = nc->flags;
2367 size_t recv_mbuf_before = nc->recv_mbuf.len, recved;
2368 ev_handler(nc, ev, ev_data MG_UD_ARG(user_data));
2369 recved = (recv_mbuf_before - nc->recv_mbuf.len);
2370 /* Prevent user handler from fiddling with system flags. */
2371 if (ev_handler == nc->handler && nc->flags != flags_before) {
2372 nc->flags = (flags_before & ~_MG_CALLBACK_MODIFIABLE_FLAGS_MASK) |
0x401092ed is in mg_ws_handler (/home/openvehicles/build/Open-Vehicle-Monitoring-System-3.1/vehicle/OVMS.V3/components/mongoose/mongoose/mongoose.c:9950).
9945 }
9946 }
9947
9948 MG_INTERNAL void mg_ws_handler(struct mg_connection *nc, int ev,
9949 void *ev_data MG_UD_ARG(void *user_data)) {
9950 mg_call(nc, nc->handler, nc->user_data, ev, ev_data);
9951
9952 switch (ev) {
9953 case MG_EV_RECV:
9954 do {
2363 }
2364 #endif
0x40108430 is in mg_close_conn (/home/openvehicles/build/Open-Vehicle-Monitoring-System-3.1/vehicle/OVMS.V3/components/mongoose/mongoose/mongoose.c:2435).
2430 mg_ssl_if_conn_close_notify(conn);
2431 }
2432 #endif
2433 mg_remove_conn(conn);
2434 conn->iface->vtable->destroy_conn(conn);
2435 mg_call(conn, NULL, conn->user_data, MG_EV_CLOSE, NULL);
2436 mg_destroy_conn(conn, 0 /* destroy_if */);
2437 }
2438
2439 void mg_mgr_init(struct mg_mgr *m, void *user_data) {
0x4010a3bb is in mg_socket_if_poll (/home/openvehicles/build/Open-Vehicle-Monitoring-System-3.1/vehicle/OVMS.V3/components/mongoose/mongoose/mongoose.c:4049).
4044
4045 for (nc = mgr->active_connections; nc != NULL; nc = tmp) {
4046 tmp = nc->next;
4047 if ((nc->flags & MG_F_CLOSE_IMMEDIATELY) ||
4048 (nc->send_mbuf.len == 0 && (nc->flags & MG_F_SEND_AND_CLOSE))) {
4049 mg_close_conn(nc);
4050 }
4051 }
4052
4053 return (time_t) now;
0x4010647a is in mg_mgr_poll (/home/openvehicles/build/Open-Vehicle-Monitoring-System-3.1/vehicle/OVMS.V3/components/mongoose/mongoose/mongoose.c:2538).
2533 LOG(LL_ERROR, ("cannot poll: no interfaces"));
2534 return 0;
2535 }
2536
2537 for (i = 0; i < m->num_ifaces; i++) {
2538 now = m->ifaces[i]->vtable->poll(m->ifaces[i], timeout_ms);
2539 }
2540 return now;
2541 }
2542
0x400fb63f is in OvmsNetManager::MongooseTask() (/home/openvehicles/build/Open-Vehicle-Monitoring-System-3.1/vehicle/OVMS.V3/main/ovms_netmanager.cpp:733).
728
729 // Main event loop
730 while (m_mongoose_running)
731 {
732 // poll interfaces:
733 if (mg_mgr_poll(&m_mongoose_mgr, 250) == 0)
734 {
735 ESP_LOGD(TAG, "MongooseTask: no interfaces available => exit");
736 break;
737 }
0x400fb6ed is in MongooseRawTask(void*) (/home/openvehicles/build/Open-Vehicle-Monitoring-System-3.1/vehicle/OVMS.V3/main/ovms_netmanager.cpp:715).
710 #ifdef CONFIG_OVMS_SC_GPL_MONGOOSE
711
712 static void MongooseRawTask(void *pvParameters)
713 {
714 OvmsNetManager* me = (OvmsNetManager*)pvParameters;
715 me->MongooseTask();
716 }
717
718 void OvmsNetManager::MongooseTask()
719 {
It seems to be a web socket (web ui?) connection went away, a logging message was produced, and that overflowed the queue. Perhaps the user is just logging too much? Can you log at debug level to web uI (or does it cause the problem I mentioned earlier about debug logging the debug logs)? Any ideas?
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200826/040e8f7c/attachment-0001.html>
