[Ovmsdev] A recent change is causing OVMS spam
Chip Cangialose
chip at cangmag.com
Mon Apr 6 07:19:19 HKT 2020
The update to the most recent production firmware (v3.2.008) seems to have resolved the problem.
Thank you.
> On 05Apr 2016, at 2:57 PM, Chip Cangialose <chip at cangmag.com> wrote:
> Thanks for the prompt response, Mark.
> Nearly every minute, I’m getting the following Notifications:
> TRS0879
> Not charging
> SOC: -
> ODO:38800.2Km..
> I erred on my current version, which is 3.1.06. I am now in the process of trying to web-flash the latest update. Hoping that solves the issue.
> Thanks, again.
> Chip
>> On 05Apr 2016, at 2:51 PM, Mark Webb-Johnson <mark at webb-johnson.net <mailto:mark at webb-johnson.net>> wrote:
>> What notification are you getting?
>>> On 6 Apr 2020, at 2:01 AM, Chip Cangialose <chip at cangmag.com <mailto:chip at cangmag.com>> wrote:
>>> Some recent update is causing me to get OVMS Notifications, one a minute. I’m still running v3.0.6. Has there been a recent polling routine added to the server?
>>> This is super annoying.
>>> Sent from my handheld
>>> From: OvmsDev <ovmsdev-bounces at lists.openvehicles.com <mailto:ovmsdev-bounces at lists.openvehicles.com>> on behalf of Craig Leres <leres at xse.com <mailto:leres at xse.com>>
>>> Sent: Saturday, April 4, 2020 11:55 AM
>>> To: OVMS Developers; Michael Balzer
>>> Subject: Re: [Ovmsdev] Ready for 3.2.011?
>>> On 2020-04-04 10:52, Michael Balzer wrote:
>>> > Adding "--recursive" is recommended, but I think you really need to merge upstream/master before doing the submodule update.
>>> > "submodule update" will update the submodules to the state as required by the current repository state. So you first need to update your branch or checkout an
>>> > updated one.
>>> Am I not updating in the correct order?
>>> #!/bin/sh
>>> set -x
>>> git fetch upstream
>>> git checkout master
>>> git submodule update --recursive
>>> git merge upstream/master
>>> git push
>>> Should the submodule update go last?
>>> Craig
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200405/c1685185/attachment.htm>
