[Ovmsdev] A recent change is causing OVMS spam
    Mon Apr  6 08:12:26 HKT 2020
It sounded like a reboot loop. Something crashing on boot causing a restart.
> On 6 Apr 2020, at 7:19 AM, Chip Cangialose <chip at cangmag.com> wrote:
> The update to the most recent production firmware (v3.2.008) seems to have resolved the problem.
> Thank you.
>> On 05Apr 2016, at 2:57 PM, Chip Cangialose <chip at cangmag.com> wrote:
>> Thanks for the prompt response, Mark.
>> Nearly every minute, I’m getting the following Notifications:
>> TRS0879
>> Not charging
>> SOC: -
>> ODO:38800.2Km..
>> I erred on my current version, which is 3.1.06.   I am now in the process of trying to web-flash the latest update.  Hoping that solves the issue.
>> Thanks, again.
>> Chip
>>> On 05Apr 2016, at 2:51 PM, Mark Webb-Johnson <mark at webb-johnson.net> wrote:
>>> What notification are you getting?
>>>>> On 6 Apr 2020, at 2:01 AM, Chip Cangialose <chip at cangmag.com> wrote:
>>>> Some recent update is causing me to get OVMS Notifications, one a minute.  I’m still running v3.0.6.  Has there been a recent polling routine added to the server?
>>>> This is super annoying.
>>>> Sent from my handheld
>>>> From: OvmsDev <ovmsdev-bounces at lists.openvehicles.com> on behalf of Craig Leres <leres at xse.com>
>>>> Sent: Saturday, April 4, 2020 11:55 AM
>>>> To: OVMS Developers; Michael Balzer
>>>> Subject: Re: [Ovmsdev] Ready for 3.2.011?
>>>> On 2020-04-04 10:52, Michael Balzer wrote:
>>>> > Adding "--recursive" is recommended, but I think you really need to merge upstream/master before doing the submodule update.
>>>> > "submodule update" will update the submodules to the state as required by the current repository state. So you first need to update your branch or checkout an
>>>> > updated one.
>>>> Am I not updating in the correct order?
>>>> #!/bin/sh
>>>> set -x
>>>> git fetch upstream
>>>> git checkout master
>>>> git submodule update --recursive
>>>> git merge upstream/master
>>>> git push
>>>> Should the submodule update go last?
>>>> Craig
>>>> OvmsDev mailing list
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200406/0c52c762/attachment.htm>
