    Stephen Casner
    casner at acm.org
    Wed Nov 27 04:24:35 HKT 2019
Michael,
Good idea.  How much time does 5 samples represent?
On Tue, 26 Nov 2019, Michael Balzer wrote:
> I've had my first false alert last night, from the log it seems caused by a single false GPS reading.
> I've added smoothing over 5 samples to the distance check, that should eliminate the false alerts unless the GPS errors are huge or persistent.
> I've also added the coordinates to the notification so we can see how large the error can become if it still occurs.
> Am 21.08.19 um 23:43 schrieb Greg D.:
> > Hmmpf.
> > Precession of the GPS constellation, perhaps?  Folks in northern Nevada
> > or Idaho should be next...
> > Greg
> > Stephen Casner wrote:
> >> Greg,
> >> Mine has been quiet for the past couple of months without increasing
> >> the alarm distance beyond the default 500 meters.
> >>                                                         -- Steve
> >> On Wed, 21 Aug 2019, Greg D. wrote:
> >>> A quick follow-up to this thread...
> >>> I've noticed that since this past spring that the number of false alerts regarding the
> >>> flatbedding of my Roadster have taken a sharp spike upward. Neither my car's normal
> >>> parking spot in the garage, nor the location of my house / garage have changed. The
> >>> difference in frequency did not appear to coincide with a firmware update, so I'm at a
> >>> bit of a loss to explain it.
> >>> Has anyone else noticed this?
> >>> Did the Government make a change to the GPS satellite fleet?
> >>> Not an issue, really, but definitely something odd going on.
> >>> Greg
> >>> Greg,
> >>> Attached are graphs of your data.  gregd.all.png shows all of the
> >>> data, and gregd.peak.png is the highest distance deviation of 369
> >>> meters, which is less than the default 500 meter threshold.
> >>> It looks like there is a diurnal pattern to the data with increased
> >>> deviations around midnight local time (the X axis times are UTC).
> >>> It also looks like your home elevation must be about 380 meters since
> >>> the altitude variable drops down to negative that amount frequently,
> >>> which would occur when that value is taken as zero (there is a special
> >>> case in the code to treat some values as zero).
> >>> I tried overlaying my data and yours, but there seems to be no
> >>> correlation between the peaks in my data and the peaks in yours.
> >>> Interestingly, my data does not show a similar diurnal pattern.
> >>>                                                         -- Steve
> >>> On Tue, 4 Jun 2019, Greg D. wrote:
> >>> 200mb of logs sent to Steve for analysis....
> >>> Greg
> >>> Thanks.  For me, today's log was much quieter.  The maximum excursion
> >>> was 115 meters and it was roughly coincident with loss of lock.
> >>>                                                         -- Steve
> >>> On Fri, 31 May 2019, Greg D wrote:
> >>> Ok.  I'll let it run for a few days and see what happens. Not planning to drive the ca
> >>> r until next week.
> >>> Greg
> >>> On May 31, 2019 2:11:31 PM PDT, Stephen Casner <casner at acm.org> wrote:
> >>> On Fri, 31 May 2019, Greg D. wrote:
> >>> Tried this, and am not getting anything written to the file system
> >>> (vfs
> >>> ls /sd shows zero bytes in gps.crtd).  Did I miss some sort of setup
> >>> step?
> >>> Nothing gets written (or at least the file size as reported is not
> >>> updated) until the recording is stopped with "can log off".
> >>>                                                        -- Steve
> >> _______________________________________________
> >> OvmsDev mailing list
> >> OvmsDev at lists.openvehicles.com
> >> http://lists.openvehicles.com/mailman/listinfo/ovmsdev
