Wed Nov 27 04:31:09 HKT 2019
Depends on the GPS source. On the modem it's 5 seconds.
If you're using GPS from the car, it depends on the sample frequency when parked / off.
But the low pass filter will pass a large step in distance also if it's a single one, so on an actual movement it will trigger before 5 samples have passed.
Am 26.11.19 um 21:24 schrieb Stephen Casner:
> Michael,
> Good idea. How much time does 5 samples represent?
> -- Steve
> On Tue, 26 Nov 2019, Michael Balzer wrote:
>> I've had my first false alert last night, from the log it seems caused by a single false GPS reading.
>> I've added smoothing over 5 samples to the distance check, that should eliminate the false alerts unless the GPS errors are huge or persistent.
>> I've also added the coordinates to the notification so we can see how large the error can become if it still occurs.
>> Am 21.08.19 um 23:43 schrieb Greg D.:
>>> Hmmpf.
>>> Precession of the GPS constellation, perhaps? Folks in northern Nevada
>>> or Idaho should be next...
>>> Greg
>>> Stephen Casner wrote:
>>>> Greg,
>>>> Mine has been quiet for the past couple of months without increasing
>>>> the alarm distance beyond the default 500 meters.
>>>> -- Steve
>>>> On Wed, 21 Aug 2019, Greg D. wrote:
>>>>> A quick follow-up to this thread...
>>>>> I've noticed that since this past spring that the number of false alerts regarding the
>>>>> flatbedding of my Roadster have taken a sharp spike upward. Neither my car's normal
>>>>> parking spot in the garage, nor the location of my house / garage have changed. The
>>>>> difference in frequency did not appear to coincide with a firmware update, so I'm at a
>>>>> bit of a loss to explain it.
>>>>> Has anyone else noticed this?
>>>>> Did the Government make a change to the GPS satellite fleet?
>>>>> Not an issue, really, but definitely something odd going on.
>>>>> Greg
>>>>> Greg,
>>>>> Attached are graphs of your data. gregd.all.png shows all of the
>>>>> data, and gregd.peak.png is the highest distance deviation of 369
>>>>> meters, which is less than the default 500 meter threshold.
>>>>> It looks like there is a diurnal pattern to the data with increased
>>>>> deviations around midnight local time (the X axis times are UTC).
>>>>> It also looks like your home elevation must be about 380 meters since
>>>>> the altitude variable drops down to negative that amount frequently,
>>>>> which would occur when that value is taken as zero (there is a special
>>>>> case in the code to treat some values as zero).
>>>>> I tried overlaying my data and yours, but there seems to be no
>>>>> correlation between the peaks in my data and the peaks in yours.
>>>>> Interestingly, my data does not show a similar diurnal pattern.
>>>>> -- Steve
>>>>> On Tue, 4 Jun 2019, Greg D. wrote:
>>>>> 200mb of logs sent to Steve for analysis....
>>>>> Greg
>>>>> Thanks. For me, today's log was much quieter. The maximum excursion
>>>>> was 115 meters and it was roughly coincident with loss of lock.
>>>>> -- Steve
>>>>> On Fri, 31 May 2019, Greg D wrote:
>>>>> Ok. I'll let it run for a few days and see what happens. Not planning to drive the ca
>>>>> r until next week.
>>>>> Greg
>>>>> On May 31, 2019 2:11:31 PM PDT, Stephen Casner <casner at acm.org> wrote:
>>>>> On Fri, 31 May 2019, Greg D. wrote:
>>>>> Tried this, and am not getting anything written to the file system
>>>>> (vfs
>>>>> ls /sd shows zero bytes in gps.crtd). Did I miss some sort of setup
>>>>> step?
>>>>> Nothing gets written (or at least the file size as reported is not
>>>>> updated) until the recording is stopped with "can log off".
>>>>> -- Steve
>>>> OvmsDev mailing list
