[Ovmsdev] Brake light control (was Re: Prototyping expansion board)
Wed May 1 21:36:25 HKT 2019
I've added the Twizy modification documentation to the user guide:
https://docs.google.com/document/d/16JrXR7rybp-18DrEoeh1rg6GqQT_jVBvhaXh2oEWRHw/edit#heading=h.xc9d76fq2q79
Tamás, have you done the modification for the i-MiEV yet?
Am 27.04.19 um 17:25 schrieb Michael Balzer:
> Tamás,
> I've pushed an optimization for the speed processing, please note you now need to call CalculateAcceleration() after your regular speed update. This is
> necessary as the speed needs to be fed into the acceleration calculation on every update, not just changes.
> I've also just added the relay to my Twizy as planned, it works nicely. Just a little caveat: as Julien foretold, the SERV light turns on while the regen
> brake light is active. So somehow the Twizy in fact does monitor the brake light current and thus recognizes the hack. Doesn't matter too much to me, I'll use
> the SERV light as my regen braking indicator ;-)
> Am 22.04.19 um 21:41 schrieb Michael Balzer:
>> Here's a simple web plugin to monitor acceleration levels and regen brake signal generation:
>> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/blob/master/vehicle/OVMS.V3/components/ovms_webserver/dev/regenmon.htm
>> Am 22.04.19 um 19:24 schrieb Tamás Kovács:
>>> Now I tested a little bit. Works fine, bright the led when recuperating.
>>> But I look at the code and I not understand:
>>> accel = (speed - m_accel_refspeed) / (now - m_accel_reftime) * 1000;
>>>  // smooth out road bumps & gear box backlash:
>>> accel = (StdMetrics.ms_v_pos_acceleration->AsFloat() * m_accel_smoothing + accel) / (m_accel_smoothing + 1);
>>> Use same variable, I think the first is unnecessary now.
>> Beg your pardon…?
>> The first line calculates the momentary acceleration, the second sends that value through a standard lowpass filter.
>> If you mean it could be written in one line, you're right, but I prefer readability.
>>> Michael Balzer <dexter at expeedo.de <mailto:dexter at expeedo.de>> ezt írta (időpont: 2019. ápr. 22., H, 11:13):
>>>     Pushed:
>>>     https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/commit/b44d466580b6961ada5ae42500c3fea68cab0f8a
>>>     - Vehicle framework: regenerative braking signal generation
>>>       New config:
>>>         vehicle [accel.smoothing] = 2.0     Acceleration smoothing factor (samples, 0 = none)
>>>         vehicle [brakelight.enable] = no    Regen brake light enable
>>>         vehicle [brakelight.port] = 1       … MAX7317 output port number (1, 3…9, default 1 = SW_12V)
>>>         vehicle [brakelight.on] = 1.3       … activation threshold (deceleration in m/s²)
>>>         vehicle [brakelight.off] = 0.7      … deactivation threshold (deceleration in m/s²)
>>>       New metrics:
>>>         v.p.acceleration    = acceleration/deceleration in m/s² derived from v.p.speed
>>>         v.e.regenbrake      = regenerative brake light state
>>>     - Twizy web UI: regenerative braking signal configuration
>>>     I've tested this using an LED on EGPIO_8, I'll do & document the Twizy hardware modification next weekend (if I receive my order in time…).
>>>     @Tamás: to add the UI to the Mitsubishi code:
>>>     https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/blob/master/vehicle/OVMS.V3/components/ovms_webserver/src/web_displays.cpp#L1127
>>>     Regards,
>>>     Michael
>>>     Am 22.04.19 um 04:12 schrieb Mark Webb-Johnson:
>>>>     Yes, EGPIO1 had to be used for SN65 control so is not available for general use.
>>>>     Max7317 has 10 outputs (P0 .. P9):
>>>>       * P0 MDM EN (controls modem power)
>>>>       * P1 SW CTL (to BTS452 for EXT 12v power control)
>>>>       * P2 EGPIO1 (SN65 transceiver power saving control)
>>>>       * P3 EGPIO2 available for general use
>>>>       * P4 EGPIO3 available for general use
>>>>       * P5 EGPIO4 available for general use
>>>>       * P6 EGPIO5 available for general use
>>>>       * P7 EGPIO6 available for general use
>>>>       * P8 EGPIO*7* available for general use
>>>>       * P9 EGPIO*8* available for general use
>>>>     Regards, Mark
>>>>>     On 22 Apr 2019, at 3:36 AM, Michael Balzer <dexter at expeedo.de <mailto:dexter at expeedo.de>> wrote:
>>>>>     Mark,
>>>>>     btw: is EGPIO_1 not free for general use? The esp32can SN65 seems to be controlled by that line.
>>>>>     Regards,
>>>>>     Michael
>>>>>     Am 21.04.19 um 15:01 schrieb Mark Webb-Johnson:
>>>>>>     If changing vehicle.{h, cpp} framework, I suggest leaving a hook in to allow the vehicle module to override / supplement this. In particular, the
>>>>>>     brake light may be controllable via can message on some vehicles.
>>>>>>     You can look at the ext12v circuit to see how to control this.
>>>>>>     The ext12v system is a switchable 12v line already wired up and available on DA26 expansion. Would be trivial to put an external relay on that to
>>>>>>     switch brake lights.
>>>>>>     Regards, Mark.
>>>>>>>     On 21 Apr 2019, at 1:32 AM, Tamás Kovács <kommykt at gmail.com <mailto:kommykt at gmail.com>> wrote:
>>>>>>>     JP1 pin 1 (+3.3) ----- [ 680 Ohms ] ---+--- [ LED ] ----- pin 28 (GND)
>>>>>>>                                         pin 12 (EGPIO_8)
>>>>>>>     I can connect a 680Ohm resistor first end to pin1, a second end to pin12, and the led positive side to pin12 and negative to pin28(gnd). Now I have
>>>>>>>     only 470ohm resistor at home, I tested now with a 4V li-ion battery and my red led power is 4mA. I can use this (470Ohm) resistor or buy a 680Ohm.
>>>>>>>     Tomorrow I remove the OVMS module from my car, and create some test, if the resistor (470Ohm) is OK.
>>>>>>>     I used this calculator for led series resistor calculation (I used a red Led): http://ledcalc.com <http://ledcalc.com/>
>>>>>>>     Michael Balzer <dexter at expeedo.de <mailto:dexter at expeedo.de>> ezt írta (időpont: 2019. ápr. 20., Szo, 11:16):
>>>>>>>         Be aware the MAX71317 outputs are open drain, so you need a pull up resistor to e.g. +3.3. According to the data sheet, the current should stay
>>>>>>>         below 6 mA.
>>>>>>>         I've just done a quick test wiring like this:
>>>>>>>                                             pin 12 (EGPIO_8)
>>>>>>>         Works as expected.
>>>>>>>         Regards,
>>>>>>>         Michael
>>>>>>>         Am 19.04.19 um 09:59 schrieb Michael Balzer:
>>>>>>>>         Sure.
>>>>>>>>         You need to route an EGPIO line to the DA26 port. For a first test you can add a simple jumper on expansion port pins 10/12 to route EGPIO_8 to
>>>>>>>>         GEP_7 (= pin 21 on DA26).
>>>>>>>>         You should then be able to use the "egpio" command to test your LED. EGPIO_1 … _8 labels correspond to MAX7317 ports 2 … 9, so to control
>>>>>>>>         EGPIO_8, do:
>>>>>>>>             OVMS# egpio output 9 1  # EGPIO_8 on
>>>>>>>>             OVMS# egpio output 9 0  # EGPIO_8 off
>>>>>>>>         (correct me if I'm wrong, Mark)
>>>>>>>>         I wasn't aware there are other cars in need of something like this. I'll think about adding the logic as an option to the vehicle framework,
>>>>>>>>         but I can send you some patch to test this on your i-MiEV/clone first.
>>>>>>>>         Regards,
>>>>>>>>         Michael
>>>>>>>>         Am 19.04.19 um 09:24 schrieb Tamás Kovács:
>>>>>>>>>         I can add for testing a simple led (with resistor) , same as SimpleConsole (twizy OVMS V2), to show car is recuperating, connected to DA26
>>>>>>>>>         external expansion port?
>>>>>>>>>         Michael Balzer <dexter at expeedo.de <mailto:dexter at expeedo.de>> ezt írta (időpont: 2019. ápr. 19., P, 9:17):
>>>>>>>>>             As the Mitsubishi code also reads battery current/power level from CAN, it would be trivial to add the same logic there.
>>>>>>>>>             Am 19.04.19 um 06:52 schrieb Tamás Kovács:
>>>>>>>>>>             The Trio (Mitsubishi I-Miev and clones) does not activate the brake light on recuperation on 2105 and older models, if this is work is
>>>>>>>>>>             very impressive.
>>>>>>>>>>             Michael Balzer <dexter at expeedo.de <mailto:dexter at expeedo.de>> ezt írta (időpont: 2019. ápr. 18., Cs, 23:08):
>>>>>>>>>>                 Mark,
>>>>>>>>>>                 that looks very good. Not sure about general demand, but I think we should have this to enable simple custom hardware I/O extensions.
>>>>>>>>>>                 For the Twizy, I was thinking about adding logic to control the brake light from the module. The Twizy does not activate the brake
>>>>>>>>>>                 light on recuperation, as that's normally (untuned) not very strong. But a tuned Twizy allows one pedal driving, so needs this.
>>>>>>>>>>                 Looking at our case I also think one custom extension board should fit on top of the modem.
>>>>>>>>>>                 Regards,
>>>>>>>>>>                 Michael
>>>>>>>>>>                 Am 18.04.19 um 02:36 schrieb Mark Webb-Johnson:
>>>>>>>>>>>                 It seems the attachments were messed up, so attaching again…
>>>>>>>>>>>                 Regards, Mark.
>>>>>>>>>>>>                 On 17 Apr 2019, at 10:07 PM, Mark Webb-Johnson <mark at webb-johnson.net <mailto:mark at webb-johnson.net>> wrote:
>>>>>>>>>>>>                     Design layout. Looks good to me, but open to suggestions...
>>>>>>>>>>>>                     We can make in sets of three PCBs, to keep prices down.
>>>>>>>>>>>>                     Regards, Mark
>>>>>>>>>>>>                 On 8 Apr 2019, at 12:05 PM, Mark Webb-Johnson <mark at webb-johnson.net <mailto:mark at webb-johnson.net>> wrote:
>>>>>>>>>>>>>                 A kit of 5 PCBs + SIP edge connectors + mounting hardware, unsoldered, would be about US$15 + shipping. About US$3/board set. With
>>>>>>>>>>>>>                 shipping I don’t think this is worth doing with less than 3 or 5 boards per kit.
>>>>>>>>>>>>>                 Would this be useful?
>>>>>>>>>>>>>                 Regards, Mark.
>>>>>>>>>>>>>>                 On 7 Apr 2019, at 9:08 PM, Mark Webb-Johnson <mark at webb-johnson.net <mailto:mark at webb-johnson.net>> wrote:
>>>>>>>>>>>>>>                 This is the closest we have today:
>>>>>>>>>>>>>>                 <image1.jpeg>
>>>>>>>>>>>>>>                 That is a bare modem board, with just the sip connectors. The prototype above is a K-line transceiver.
>>>>>>>>>>>>>>                 I think it would be trivial, and cheap, to make up what you show. Perhaps just solder ready pads at 0.1” pitch, then the side sip
>>>>>>>>>>>>>>                 connectors wired to the first row of pads at each edge. Perhaps 5 PCBs in a kit, with sip edge connectors, unsoldered, in a
>>>>>>>>>>>>>>                 simple plastic bag.
>>>>>>>>>>>>>>                 Does that sound like something useful? If so, I can ask the China guys for some idea of pricing. If it is just the unsoldered
>>>>>>>>>>>>>>                 pcbs + parts, I don’t think it will be expensive.
>>>>>>>>>>>>>>                 Regards, Mark
>>>>>>>>>>>>>>                 On 7 Apr 2019, at 4:38 PM, Michael Balzer <dexter at expeedo.de <mailto:dexter at expeedo.de>> wrote:
>>>>>>>>>>>>>>>                 Mark,
>>>>>>>>>>>>>>>                 do you know of some kind of prototyping board available that fits to our piggy back expansion layout?
>>>>>>>>>>>>>>>                 Something like this: https://www.robotshop.com/de/de/cytron-arduino-proto-schild.html
>>>>>>>>>>>>>>>                 Regards,
>>>>>>>>>>>>>>>                 Michael
>>>>>>>>>>>>>>>                 Am 03.04.19 um 06:48 schrieb Mark Webb-Johnson:
>>>>>>>>>>>>>>>>                 If you have work to do on this DA26 expansion ports, this is pretty cool and well built:
>>>>>>>>>>>>>>>>                     https://www.aliexpress.com/item/26-Pin-D-SUB-DB26-3-Rows-Serial-Parallel-Port-Serial-Shellless-Male-And-Female-Connector/32886738786.html?spm=a2g0s.9042311.0.0.20924c4dg34EEU
>>>>>>>>>>>>>>>>                 _______________________________________________
>>>>>>>>>>>>>>>>                 OvmsDev mailing list
>>>>>>>>>>>>>>>>                 OvmsDev at lists.openvehicles.com <mailto:OvmsDev at lists.openvehicles.com>
>>>>>>>>>>>>>>>>                 http://lists.openvehicles.com/mailman/listinfo/ovmsdev
>>>>>>>>>>>>>>>                 Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal
>>>>>>>>>>>>>>>                 Fon 02333 / 833 5735 * Handy 0176 / 206 989 26
>>>>>>>>>>             Üdvözlettel:
>>>>>>>>>>             Kovács Tamás
>>>>>>>>>         Üdvözlettel:
>>>>>>>>>         Kovács Tamás
>>>>>>>     Üdvözlettel:
>>>>>>>     Kovács Tamás
>>> Üdvözlettel:
>>> Kovács Tamás
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20190501/d08f1380/attachment-0001.html>
