[Ovmsdev] Some question
    Wed May  1 22:09:24 HKT 2019
Tamás,
Am 01.05.19 um 14:49 schrieb Tamás Kovács:
> Can I trace only one specified metrics?
Not using the shell, but it's pretty simple using a web plugin.
See https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/blob/master/vehicle/OVMS.V3/components/ovms_webserver/dev/metrics.htm
> I want to find some metrics, can I see only variable datas on CAN network? First I want to get the ambient temperature and the cabin temp values, I though
> heat the sensor environment and check the variable data, then I only get the formula to use this pid in metric.
Check out the RE tools for this.
