[Ovmsdev] can log
Tamás Kovács
kommykt at gmail.com
Tue Jun 18 11:56:58 HKT 2019
Now i remove the SD card in my Mac the speed is 10MB/s / 80MB /s (W/R).
I have a 1.5 year old modell with the following numbers (2018020219PTWU)
If run ‘config list sdcard’ only show 'sdcard (readable writeable)'
if i run 'config set sdcard maxfreq.khz 16000' now show this value for
‘config list sdcard’.
For download, if i copy the log to another folder than sd root, i can
browse the folder tree, and download directly.
Mark Webb-Johnson <mark at webb-johnson.net> ezt írta (időpont: 2019. jún.
18., K, 2:14):
> Tamás,
> Yes, it seems SD CARD is too slow.
> Can you check ‘config list sdcard’ and see if you have a ‘maxfreq.khz’
> value set? The default is 16000.
> If you have a reasonably modern OVMS module, or are running from USB power
> (even if 12v is connected as well), you can set:
> config set sdcard maxfreq.khz 20000
> and reboot, to improve the SD CARD write speed.
> The 1R11 means reception of a 11bit (standard) CAN message on CAN1 bus. A
> 1T11 would mean transmission. I think you should be able to download via
> the browser - personally, I just scp the files off the module over wifi.
> On 15 Jun 2019, at 1:58 AM, Tamás Kovács <kommykt at gmail.com> wrote:
> I want to create log file from can messages while Lexia connected to obd,
> but many message has dropped. My sd card is too slow to write all data?
> I start logging with can log crtd /sd/lexia.crtd command
> Closing log: Type:crtd; Path:'/sd/lexia.crtd'; Filter:off; Vehicle:MI;
> Statistics: total messages: 3334194, dropped: 2707476 = 81.2%
> In can log i can see the incoming messages?
> This is a RX message:
> 175594.785 1R11 346 27 10 40 00 00 00 00 42
> if 1R11 is 1T11 this is a TX message on CAN1?
> How can i download the log file, the easiest way, because if i use browser
> and add the file url (ip/lexia.crtd) the browser load its content.
Üdvözlettel:
Kovács Tamás
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20190618/c2aebcc6/attachment.htm>
