[Ovmsdev] v3.2 hardware schematics and PCB layout
Olivier ogrums at gmail.com
Tue Jun 11 17:32:19 HKT 2019
Hello,
For the futur, can we imagine a HAT or directly install on the main board,
a mPCI-E interface like this :
https://sixfab.com/product/raspberry-pi-3g-4glte-base-shield-v2/
Is it even compatible with interface available on ESP32 ?
Olivier
Le lun. 10 juin 2019 à 11:24, Mark Webb-Johnson <mark at webb-johnson.net> a
écrit :
> I’ve uploaded the v3.2 hardware schematics and PCB layout files. The
> boards are labelled ‘v3.2’ and this is the version that was recently FCC
> and CE certified. The only changes are related to EMC, and addition of
> components to bring that under control (doing it at board level avoids the
> need to change vehicle cables). We also made minor three component changes
> to meet ROHS requirements (a micro USB connector, and the red plastic dust
> caps on the antennas). You can find these documents in
> the vehicle/hardware/v3.2 directory.
> The first v3.2 hardware has completed all testing, and production of the
> first batch is in progress. We are finalising the CE and FCC documentation.
> EU kits (with CE conformity) should be available within the next week or
> two at Fasttech, and shortly after that at shop.openenergymonitor.com (for
> direct distribution within EU).
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20190611/c25a4ad3/attachment.htm>
Type: image/png
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20190611/c25a4ad3/attachment-0004.png>
Type: image/png
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20190611/c25a4ad3/attachment-0005.png>
