[Ovmsdev] v3.2 hardware schematics and PCB layout
Tue Jun 11 19:18:40 HKT 2019
These expansion boards under manufacturing as we speak. mPCI-E is unlikely to be feasible for the small embedded ARM processor we use. Can be configured to work as expansion on top of existing modem, or without.
Our modular modem boards are pretty flexible, and we can swap out modems for newer technology, without changing the motherboard.
> On 11 Jun 2019, at 5:32 PM, Olivier <ogrums at gmail.com> wrote:
> Hello,
> For the futur, can we imagine a HAT or directly install on the main board, a mPCI-E interface like this :
> https://sixfab.com/product/raspberry-pi-3g-4glte-base-shield-v2/ <https://sixfab.com/product/raspberry-pi-3g-4glte-base-shield-v2/>
> Is it even compatible with interface available on ESP32 ?
> Olivier
> Le lun. 10 juin 2019 à 11:24, Mark Webb-Johnson <mark at webb-johnson.net <mailto:mark at webb-johnson.net>> a écrit :
> I’ve uploaded the v3.2 hardware schematics and PCB layout files. The boards are labelled ‘v3.2’ and this is the version that was recently FCC and CE certified. The only changes are related to EMC, and addition of components to bring that under control (doing it at board level avoids the need to change vehicle cables). We also made minor three component changes to meet ROHS requirements (a micro USB connector, and the red plastic dust caps on the antennas). You can find these documents in the vehicle/hardware/v3.2 directory.
> The first v3.2 hardware has completed all testing, and production of the first batch is in progress. We are finalising the CE and FCC documentation. EU kits (with CE conformity) should be available within the next week or two at Fasttech, and shortly after that at shop.openenergymonitor.com <http://shop.openenergymonitor.com/> (for direct distribution within EU).
> OvmsDev at lists.openvehicles.com <mailto:OvmsDev at lists.openvehicles.com>
> http://lists.openvehicles.com/mailman/listinfo/ovmsdev <http://lists.openvehicles.com/mailman/listinfo/ovmsdev>
> <mPCI-E 2.PNG><mPCI-E.PNG>_______________________________________________
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20190611/09ed6e22/attachment.htm>
Type: image/png
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20190611/09ed6e22/attachment-0004.png>
Type: image/png
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20190611/09ed6e22/attachment-0005.png>
