[Ovmsdev] BUG? in v3.2.0-1 in vehicle_mitsubishi - flood of BMS-error msg
Michael Eric Menk mikeemenk at gmail.com
Sat Jan 19 21:08:15 HKT 2019
There is a bug in MIEV code, that bombs the web GUI and phone APP with BMS errors.
I suspect that this is  because the Peugeot and Citroen branded MIEVs have a 80 cell battery pack vs MIEVs  88cells.
Sample of a message:
> Voltage: SD=1mV OK
> Temperature: SD=1.4C !6:+3.1C !16:+3.1C !18:+3.1C
The missing cells could also be used to set the voltage gauge.
There are two LEV50-4 missing in the 80 cell pack, number 06 and 12.
If a flagg is set while looping the CAN massages, then the flag can be used inside
OvmsVehicleMitsubishi::GetDashboardConfig to set correct voltage.
The float charge voltage of the 80 cell pack is 328.4 volt
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20190119/57eedc9f/attachment.html>
