[Ovmsdev] Fwd: [ovms:2087] Consult on Renault twizy
Wed Sep 19 16:03:49 HKT 2018
Thanks. That makes sense (I was looking in vehicle_twizy folder, and app sources).
You mention a twizy user guide? Do you have a link for that, so I can add it to the website?
> On 19 Sep 2018, at 3:59 PM, Michael Balzer <dexter at expeedo.de> wrote:
> For the record:
>> In order to send commands to the Twizy, you need to enable CAN write access.
>> You can do so either by using the web UI or by setting feature 15 to 1 or by issuing "config set xrt canwrite yes".
> @Mark: the error text is defined here:
> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/blob/master/vehicle/OVMS.V3/components/canopen/src/canopen.cpp#L373 <https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/blob/master/vehicle/OVMS.V3/components/canopen/src/canopen.cpp#L373>
> Am 19.09.18 um 04:09 schrieb Mark Webb-Johnson:
>> @michael,
>> Could you help this user? I greped for the error text in OVMS v2, v3 and Android, source code, but can’t find it.
>> <Screenshot_20180918-222459.png>
>>> Begin forwarded message:
>>> bricoauto has created the ticket 'Consult on Renault twizy':
>>> https://www.openvehicles.com/node/2087#comment-0 <https://www.openvehicles.com/node/2087#comment-0>
>>> State: new
>>> Priority: normal
>>> You can visit the following URL to update this ticket:
>>> https://www.openvehicles.com/node/2087#comment-form <https://www.openvehicles.com/node/2087#comment-form>
>>> Ticket text:
>>> I have successfully installed the Ovms 3.1 module in my renault twizy, but I
>>> still do not know how to modify parameters. For example with the App, if I
>>> want to modify the speed limitation, it tells me the following error message:
>>> Can bus not in active mode
>>> I guess that writing or reading by can not be active, because I can not see
>>> the fault logs etc ...
>>> Could you help me with this?
>>> Regards!
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180919/843e7125/attachment.html>
